SSH on 6513 Switch
imuonagor
I wish to disable Telnet and configure ssh on Cisco 6513 switch with the following ios version:
Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICES_WAN-M), Version 12.2 (33)SXI
However the regular ssh configurations (crypto key generate rsa) are not being accepted by the switch.
I'll appreciate some help on this please.
Thanks in advance!
Collin Clark
There's a bug. You'll need to grab a new version of IOS.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtc41114
Requires a CCO login.
Cisco will donate $1 to the Red Cross Haiti fund for every rated post!
https://supportforums.cisco.com/docs/DOC-8727
http://www.joomlatabs.com/thermometer/thermo.php?max=10000&current=82&var=lt&color=red
Mark Yeates
Level 7
Level 7
It appears that you do not have a "crypto" IOS. To keep the same feature set you currently have you will need the        IP SERVICES SSH IOS to support SSH. After you run the correct IOS you should be able to input the proper SSH commands.
HTH,
Mark
