SSH problem C3650
se.dejbjerg
Frequent Visitor
Frequent Visitor
As shown below I have a network with two L3 switches CoreSW C6500 and S2 C3650, they form OSPFv3 adjacency over vlan 724. The following networks 192.168.60.0/24 and 172.24.0.0/24 are all part of area 0, on S2 172.24.x.0/24 are all part of area 24 except 172.24.0.0/24 that is part of area 0.
Vlan 2 is not a part of OSPF. On the CoreSW there is a default static route to the internet, this default static route is redistributed with default-information originate on the CoreSW.
When adjacency is established between the CoreSW and S2 I can successfully ping and ssh to the management ip on S2.
After lost adjacency between CoreSW and S2 fx. shutdown on interface vlan 724 on CoreSW, I can no longer SSH to S2 but I can still ping S2. If I loose adjacency while the ssh connection is established the connection continues, until I terminate it.
A debug ip policy on S2 shows that the PBR on S2 is working.
Any help is appreciated.
8 Replies 8
Georg Pauwen
post the full running configurations of both switches.
Here is the running-config for CoreSW and S2
 Can you share the config from both switches?
two point
1-InterVLAN in CoreSW use 172.24.0.0 to route the traffic not the 192.168.2.0 and this I think why that the PBR not work.
2-check SSH line it idle or not
Hello, sorry pressed the wrong Reply button, pls. se my post below.
se.dejbjerg
Frequent Visitor
Frequent Visitor
When the interface vlan 724 is shutdown on CoreSW the 172.24.0.0/24 network don't show up in the routing table, but still vlan 2 as a connected network, and on S2 there is only two connected networks the 172.24.0.0/24 and 192.168.2.0/24 in the routing table. and no default route.
can you do tracertoute and share here ?
do trace route from both side
PC to SW
SW to PC
Hello
Here is a traceroute from PC and S2 and SSH from PC to S2, with and without adjacency on vlan 724.
