STAC COMPRESSION
timmysyed
Visitor
Hello
I have enabled STAC Compression on HDLC Serial Link. I choose 8192 Bytes ICMP to test the compression and got below results. I run it three times and got three different compression ratio .
FIRST TIME :
R2#ping 20.0.24.2 repeat 1 size 8192 timeout 2
Sending 1, 8192-byte ICMP Echos to 20.0.24.2, timeout is 2 seconds:
Success rate is 100 percent (1/1), round-trip min/avg/max = 40/40/40 ms
R2#show compress
 Serial0/0
         Software compression enabled
         uncompressed bytes xmt/rcv 8452/8372
         compressed bytes   xmt/rcv 573/510
         Compressed bytes sent:       573 bytes   0 Kbits/sec  ratio: 14.750
         Compressed bytes recv:       510 bytes   0 Kbits/sec  ratio: 16.415
         1  min avg ratio xmt/rcv 12.943/14.286
         5  min avg ratio xmt/rcv 12.943/14.286
         10 min avg ratio xmt/rcv 12.943/14.286
         no bufs xmt 0 no bufs rcv 0
         resyncs 0
         Additional Stac Stats:
         Transmit bytes:  Uncompressed =       40 Compressed =        573
         Received bytes:  Compressed =        538 Uncompressed =        0
SECOND TIME:
Success rate is 100 percent (1/1), round-trip min/avg/max = 52/52/52 ms
R2#show compress
 Serial0/0
         uncompressed bytes xmt/rcv 8372/8452
         compressed bytes   xmt/rcv 507/574
         Compressed bytes sent:       507 bytes   0 Kbits/sec  ratio: 16.512
         Compressed bytes recv:       574 bytes   0 Kbits/sec  ratio: 14.724
         1  min avg ratio xmt/rcv 14.976/13.415
         5  min avg ratio xmt/rcv 14.976/13.415
         10 min avg ratio xmt/rcv 14.976/13.415
         resyncs 0
         Transmit bytes:  Uncompressed =       20 Compressed =        507
         Received bytes:  Compressed =        606 Uncompressed =        0
Third Time :
Success rate is 100 percent (1/1), round-trip min/avg/max = 84/84/84 ms
R2#show compress
 Serial0/0
         uncompressed bytes xmt/rcv 8850/8850
         compressed bytes   xmt/rcv 936/938
         Compressed bytes sent:       936 bytes   0 Kbits/sec  ratio: 9.455
         Compressed bytes recv:       938 bytes   0 Kbits/sec  ratio: 9.434
         1  min avg ratio xmt/rcv 8.444/8.428
         5  min avg ratio xmt/rcv 8.444/8.428
         10 min avg ratio xmt/rcv 8.444/8.428
         resyncs 0
         Transmit bytes:  Uncompressed =       60 Compressed =        936
         Received bytes:  Compressed =        978 Uncompressed =        0
1. Three time three different ratio why it is so ? Am i missing anything to understand here ?
2. I see only difference in the field Additional Stac Stats: Transmit bytes:  Uncompressed  Field.
3. Is Transmit bytes : Uncompressed filed is Header field and this reason its not compressed ?
TIM
Georg Pauwen
as far as I recall, STAC is less predictable and consistent than Predictor. Your response times vary, that alone might cause the difference in compression rates. Do you get the same with 'compress predictor' ?
https://www.cisco.com/c/en/us/support/docs/wan/data-compression/14156-compress-overview.html
Thanks for the reply but i have not yet tried Predictor.
May be the its due to ICMP Packets ? where we dont know the randomness of payload. May be give more stable result when actually traffic pass through ?
Any update on my point 2 and Point 3 ?
I d
