Stack Power Cable
Armymanryno
Level 3
Level 3
I need a stack power cable for a cisco 9300. I have a 3750x stack power cable on hand. Will that work with 9300s?
2 Accepted Solutions
Stack Cables are different for 9300 and 3750. You can find the buying information and part number of stack cables for 9300 in the below link.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/nb-06-cat9300-ser-data-sheet-cte-en.html
Spooster IT Services Team
Stonent
Level 4
Level 4
I know this is an old thread but it looks like nobody answered the specific question he was asking.  He specifically asked about stack power cables not stack data.  When I got in some 9300s and saw the cable, they looked familiar.  I looked in my drawer of old cables and found a bunch of 3750X stack power cables and they appear to be identical and fit in either switch.  When googling for 9300 stack power cables I get hits for 3750X and 3850X cables.
Also cisco appears to have reused the stack cables from the 3850 on the 9300.  Now you probably can't stack those two together but the cables should be reusable.
Stonent, CCNA
5 Replies 5
Seb Rupik
Hi there,
The connector layout on both cables are wildly different and will not fit.
cheers,
Seb.
Martin L
Nope, 3750 differ from next model 3850,as well as from previous one , 3650X,
Stonent
Level 4
Level 4
Stonent, CCNA
I appreciate you responding! Thanks
