Changed port numbers on a switch
brianw360
Came across this curious "sh int status" results on a non-stacked Cisco WS-C3850-12XS switch.  This is an OT switch and it would be nice to know how to get it so that the gi ports read 1/0/1-24.  I was thinking in global configuration mode. Issue the command switch current-stack-member-number renumber new-stack-member-number, but wanted some validation if that would work.  No issues aside from the WTH factor.  TIA!
WAU-MIS-CORE1#sho int status
Port Name Status Vlan Duplex Speed Type
Te1/0/1 WAU-SCV-DIST1_t1/1 connected trunk full 1000 1000BaseLX SFP
Te1/0/2 WAU-STEAM-DIST1_t1 connected trunk full 10G SFP-10GBase-LRM
Te1/0/3 notconnect 1 auto auto unknown
Te1/0/4 notconnect 1 auto auto unknown
Te1/0/5 notconnect 1 auto auto unknown
Te1/0/6 notconnect 1 auto auto unknown
Te1/0/7 notconnect 1 auto auto unknown
Te1/0/8 notconnect 1 auto auto unknown
Te1/0/9 connected trunk full 10G SFP-10GBase-LR
Te1/0/10 disabled 1 full 10000 SFP-10GBase-LRM
Te1/0/11 WAU-MIS-DCS1_t1/0/ connected trunk full 10G SFP-10G-ACTIVE-CABLE
Te1/0/12 WAU-PM6-CORE1_te1/ connected trunk full 10G SFP-10GBase-LR
Gi2/0/1 WAU-MIS-AGG1_g1/0/ connected trunk a-full a-1000 10/100/1000BaseTX SFP
Gi2/0/2 WAU-PM5-PL3S1_g0/1 connected trunk full 1000 1000BaseLX SFP
Gi2/0/3 WAU-PM1C-PL3S1_g0/ connected trunk full 1000 1000BaseLX SFP
Gi2/0/4 WAU-NCVE-PS1_g3/0/ notconnect 1 full 1000 1000BaseLX SFP
Gi2/0/5 WAU-PM7-PL3S1_g1/0 connected trunk full 1000 1000BaseLX SFP
Gi2/0/6 WAU-PM6-PL3S1_g1/0 connected trunk full 1000 1000BaseLX SFP
Gi2/0/7 WAU-SCVS-MS1_f0/25 disabled 1 half 100 100BaseFX SFP
Gi2/0/8 WAU-PM7N-MS1_g0/1 connected trunk full 1000 1000BaseLX SFP
Gi2/0/9 notconnect 1 auto auto unknown
Gi2/0/10 notconnect 1 auto auto unknown
Gi2/0/11 notconnect 1 auto auto unknown
Gi2/0/12 notconnect 1 auto auto unknown
Gi2/0/13 notconnect 1 auto auto unknown
Gi2/0/14 BrianPCN_Desktop connected 1 a-full a-10 10/100/1000BaseTX SFP
Gi2/0/15 connected trunk a-full a-1000 10/100/1000BaseTX SFP
Gi2/0/16 connected trunk a-full a-1000 10/100/1000BaseTX SFP
Gi2/0/17 connected trunk a-full a-1000 10/100/1000BaseTX SFP
Gi2/0/18 connected trunk a-full a-1000 10/100/1000BaseTX SFP
Gi2/0/19 notconnect 1 auto auto unknown
Gi2/0/20 PRI_FW_port_12_(Ma connected 1 a-full a-1000 10/100/1000BaseTX SFP
Gi2/0/21 notconnect 1 auto auto unknown
Gi2/0/22 DeltaV-FW-Pri_WAN2 connected 1 a-full a-1000 10/100/1000BaseTX SFP
Gi2/0/23 OR227SWM01001_g3/1 notconnect 1 full 1000 1000BaseSX SFP
Gi2/0/24 PRI_FW_port_12_(Ma notconnect 1 auto auto unknown
WAU-MIS-CORE1#
Reza Sharifi
if "switch 1 provision WS-C3850-12XS" does not work, you may want to try
no switch 1 provision
and reboot.
Thank you...it'll be a while before I can attempt to reboot the switch.  But I just wanted to see what other more knowledgeable people would suggest.
One more thing. If the switch was never in a stack before and is behaving like this, it maybe a bug in the OS you are running. So, if the above suggestions don't fix it, an upgrade may do.
