Stack trace errors: Cisco Catalyst 3030
dmooreami
Level 5
Level 5
Yes, I know the Catalyst 3030 is EOL/EOS and I am probably SOL.
Cisco IOS Software, CBS30X0 Software (CBS30X0-LANBASE-M), Version 12.2(25)SEE2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Fri 28-Jul-06 11:05 by yenanh
Image text-base: 0x00003000, data-base: 0x00AB4EB8
ROM: Bootstrap program is CBS30X0 boot loader
BOOTLDR: CBS30X0 Boot Loader (CBS3030-HBOOT-M) Version 12.2(25r)SEE, RELEASE SOFTWARE (fc1)
Boca-PE-1955-SW1 uptime is 8 minutes
System returned to ROM by error - Program Exception (0x0700)!, PC 0xFEA10EC0
System restarted at 10:06:14 est Thu Nov 22 2012
System image file is "flash:cbs30x0-lanbase-mz.122-25.SEE2/cbs30x0-lanbase-mz.122-25.SEE2.bin"
cisco WS-CBS3030-DEL (PowerPC405) processor (revision A0) with 118784K/12280K bytes of memory.
Processor board ID FOC1136H00Q
Last reset from power-on
2 Virtual Ethernet interfaces
16 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:1B:8F:C7:20:00
Motherboard assembly number     : 73-10292-05
Motherboard serial number       : FOC11342L0T
Model revision number           : A0
Motherboard revision number     : A0
Model number                    : WS-CBS3030-DEL-F
Daughterboard assembly number   : 73-10432-05
Daughterboard serial number     : FOC11342GJM
System serial number            : FOC1136H00Q
Top Assembly Part Number        : 800-27423-01
Top Assembly Revision Number    : B0
Version ID                      : V01
CLEI Code Number                : COUIAD8CAA
Daughterboard revision number   : A0
Hardware Board Revision Number  : 0x01
Switch   Ports  Model              SW Version              SW Image
*    1   16     WS-CBS3030-DEL     12.2(25)SEE2            CBS30X0-LANBASE-M
I would like to put the below into the "stack trace" tool, but all links appear to be dead.
Anybody got a live link or know what this means?
%PLATFORM-1-CRASHED: Program Exception (0x0700)!
%PLATFORM-1-CRASHED: SRR0 = 0xFEA10EC0 SRR1 = 0x00029210 SRR2 = 0x0043CD70 SRR3 = 0x00021200
%PLATFORM-1-CRASHED: ESR = 0x08000000 DEAR = 0x00000000 TSR = 0x8C000000 DBSR = 0x00000000
%PLATFORM-1-CRASHED: CPU Register Context:
%PLATFORM-1-CRASHED: Vector = 0x00000700 PC = 0xFEA10EC0 MSR = 0x00029210 CR = 0x39000099
%PLATFORM-1-CRASHED: LR = 0x005E9C90 CTR = 0x005E9C74 XER = 0xC0000000
%PLATFORM-1-CRASHED: R0 = 0x00A406F0 R1 = 0x01767100 R2 = 0x00000000 R3 = 0x01206F78
%PLATFORM-1-CRASHED: R4 = 0x01767108 R5 = 0x0100DB1C R6 = 0x0100DBF0  R7 = 0x00000000
%PLATFORM-1-CRASHED: R8 = 0x00029210 R9 = 0x01200000 R10 = 0x01200000 R11 = 0x00F40000
%PLATFORM-1-CRASHED: R12 = 0x00068100 R13 = 0x00090000 R14 = 0x007CA994 R15 = 0x00000000
%PLATFORM-1-CRASHED: R16 = 0x00000000 R17 = 0x00000000 R18 = 0x00000000 R19 = 0x00000000
%PLATFORM-1-CRASHED: R20 = 0x00000000 R21 = 0x00000000 R22 = 0x00000000 R23 = 0x00000000
%PLATFORM-1-CRASHED: R24 = 0x00000000 R25 = 0x00000000 R26 = 0x00000000 R27 = 0x00000000
%PLATFORM-1-CRASHED: R28 = 0x007CA974 R29 = 0x00000000 R30 = 0x00000000 R31 = 0x01200000
%PLATFORM-1-CRASHED: Stack trace:
%PLATFORM-1-CRASHED: PC = 0xFEA10EC0, SP = 0x01767100
%PLATFORM-1-CRASHED: Frame 00: SP = 0x01767110   PC = 0x0162558C
%PLATFORM-1-CRASHED: Frame 01: SP = 0x01767128   PC = 0x00A406F0
%PLATFORM-1-CRASHED: Frame 02: SP = 0x01767138   PC = 0x007CA9B8
%PLATFORM-1-CRASHED: Frame 03: SP = 0x01767140   PC = 0x00A7C2D0
%PLATFORM-1-CRASHED: Frame 04: SP = 0x00000000    PC = 0x00A72898
Arumugam Muthaiah
I decoded the stack trace but unfortunately this is not pointing any software or hardware issue. Is it the first time do you see this issue? or do you see this same crash often.
If you see this same crash again, the replacement will fix this issue.
Aru
*** Please rate if the post is useful ***
Regards, Aru *** Please rate if the post useful ***
Leo Laohoo
Two things I see here:
1.  Your blade has crashed.  If this is so, then there should be a series of detailed files/subdirectories called "crashinfo".  Post the last 4.
2.  You are running an ancient IOS.  Please upgrade to, say, 12.2(55)SE6.  Do not attempt to load any IOS higher than what I've proposed.  It's full of bugs.
dmooreami
Level 5
Level 5
Thanks to all for replying.
I replaced the Cat 3030 tossing out stack strace errors with another Cat 3030 running the same code. Problems have vanished!
