02-08-2021 03:15 AM
Hi All!
We have an interesting proble!
4 pcs stacked WS-C3750X-48PF-L rebooted (Power outage).
After reboot, 3 member is okay, 1 member lost.
This stack is running ~1,5 year, without restart.
We checked the failed member, and switch type is changed!!!!
Switch#sh inv
NAME: "4", DESCR: "SW-6750X-48P"
PID: WS-C3750X-48PF-L , VID: V05 , SN: FDO1751R12S
What?? how is it possible?!
I removed all configuration (clear flash), but not changed.
What happened?This is Fake cisco switch? or what?
Switch#sh ver
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 15.2(4)E8, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Fri 15-Mar-19 09:00 by prod_rel_team
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(58r)SE1, RELEASE SOFTWARE (fc1)
Switch uptime is 30 minutes
System image file is "flash:/c3750e-universalk9-mz.152-4.E8.bin"
Last reload reason: Reload command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco SW-6750X-48P (PowerPC405) processor (revision A0) with 262144K bytes of memory.
Processor board ID FDO1751R12S
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
52 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : B8:38:61:1D:8A:00
Motherboard assembly number : 73-12553-10
Motherboard serial number : FDO17510MNP
Model revision number : A0
Motherboard revision number : C0
Model number : WS-C3750X-48PF-L
Daughterboard assembly number : 800-32727-03
Daughterboard serial number : FDO17510NJ6
System serial number : FDO1751R12S
Top Assembly Part Number : 800-31324-08
Top Assembly Revision Number : E0
Version ID : V05
CLEI Code Number : COMJZ00ARE
Hardware Board Revision Number : 0x05
Switch Ports Model SW Version SW Image
* 4 54 SW-6750X-48P 15.2(4)E8 C3750E-UNIVERSALK9-M
Configuration register is 0xF
Switch#sh inv
NAME: "Switch 4 - Power Supply 1", DESCR: "FRU Power Supply"
PID: C3KX-PWR-1100WAC , VID: V02L , SN: LIT17441D69
02-08-2021 03:36 AM
This is a known "bug".
I have seen that output before.
02-08-2021 03:42 AM
And what is the solution?
I couldn't find a solution!
02-08-2021 06:27 AM
solution:
after boot, switch model number is good:
cisco WS-C3750X-48P (PowerPC405) processor (revision T0) with 262144K bytes of memory.
I still had to licence downgrade (ip to lan), and stack is working again!
Thx your help!
08-26-2022 04:05 PM
Thanks a lot, it works for me:
Ronmon State and enter:
set MODEL_NUM WS-C3750X-48PF-E
MODEL_REVISION_NUM=T0
VERSION_ID=V06
switch: flash _init
boot
After that, connect stack cables, configure priority on others switches and then reload
Regards!!
08-26-2022 06:33 PM
Sure this happens because some of the devices have longer uptime, so always need to prepare to have a console to get access and fix the issue if any issue encountered like this, good to know all is resolved.
02-08-2021 04:39 AM
Looks cosmetic bug, if this is not effecting Services, ignore it.
when you get chance and maintenance window upgrade to 15.2.4E10 and test it.
