07-02-2018 11:35 AM - edited 03-08-2019 03:32 PM
I Have two WS-C2960S-24TS-L And I Want To Stack Between Them!! Can I Do This ?! what i need??
07-02-2018 11:43 AM
Yes, You can configure in Stack.
Deepak Kumar
07-02-2018 11:44 AM
You can but you need to install the Flex stack module in each switch first.
Here is the part number
WS-C2960S-STACK
07-02-2018 02:07 PM
Hello, others already pointed out you need stack modules and cables.
What do you want to do with those? Are they access switches for pc, servers or arethey your core switches? Maybe we can recommend you some nice things depending of the use case.
