Stacking 9300x-24Y and 9300-48P with no Redundancy
Coops72
Switch Ports Model SW Version SW Image Mode
* 1 54 C9300X-24Y 17.09.05 CAT9K_IOSXE INSTALL
2 54 C9300X-24Y 17.09.05 CAT9K_IOSXE INSTALL
I want the switches to be configured with no redundancy, but despite running switch clear stack-mode I the two  switches C9300X still re-organise back:
show switch stack-mode
Switch# Role Mac Address Version Mode Configured State
*1 Active 8c44.a5e2.bc80 V03 N+1' None' Ready
2 Standby b44c.90c6.4b80 V03 N+1' None' Ready
How can I have these switches stacked, but without redundancy? Thanks for any tips.
marce1000
       - Check logs , on  both switches after issuing the clear stack-mode command , check for issues if any ,
 M.
I tried that, and after a reload, it reverts back to Active / Standby.
Not sure i have addresses some of the information on the above post ?
Not sure what you referring here, you referring active  and standby, that is for stacking, not for stack power.
BB
balaji.bandi
I would suggest to understand the Stack Power redundancy here :
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/white-paper-c11-741945.html
when you issue  switch clear stack-mode command to remove 1:1 stack mode, and change it back to N+1 stack mode.
Other way you don't want redundancy at all, remove the stack power cable.
BB
