Stacking C9300-24UX and C9300-24P?
Chris.Mes
Can I stack C9300-24UX and C9300-24P together?
I think it should be possible.
I found Cisco documentation which is saying that you can not Stack C9300 and C9300-24UXB.
But I think C9300-24UXB is different to C9300-24UX?
Does anybody know exactly if I can stack C9300-24UX and C9300-24P?
Thanks.
Leo Laohoo
UXB will only stack with UXB.
Sorry - Leo is correct.
CCO is confusing at times
The data sheet says something different re the stacking
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/nb-06-cat9300-ser-data-sheet-cte-en.html
"Catalyst 9300 higher scale SKUs (C9300-24UB, C9300-24UXB, C9300-48UB) need to be stacked with other higher scale models."
Regards, Alex. Please rate useful posts.
acampbell
Yes you can stack these together.
They are both 480G stackwise ready.
Please read this book/chapter
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/hardware/install/b_c9300_hig/m_9300_installing_the_switch.html#concept_29A3FEEE54C847BC8B792C453F7FA612
balaji.bandi
Mixed stacking between Catalyst 9300 and Catalyst 9300X and Catalyst 9300 higher scale models (C9300-24UB, C9300-24UXB, C9300-48UB) is not supported.
BB
