Stacking Cables between Different models
ajay kondapalli
Is there any limitations in using Stacking Switces using Stack Cables on Different model switches like Cisco 3750, Cisco 4948 etc.
If we use 2 cisco 3750 swithces and other as 4948 swithces  as the Stack members using Stack cables.  Will there be any problem or limitations in Stackwise technology ?
Should we use same model switches in a single stack ?
Ajay
Reza Sharifi
You can stack together any of the 3750 models, but you cannot stack 3750s with 4948.
I don';t think 4948 is stackable..Only some 2k and 3k models are stackable.
