Stacking WS-C3750-48PS-S and WS-C3750G-48PS.
forman102
I have 3750-48PS-S in production and would like to stack it with C3750G-48PS. Both switches are running code:
c3750-ipservicesk9-mz.122-50.SE3.bin
Please confirm this configuration will work.
Thank you,
forman
smogra
Yes you can do it. This configuration will work.
Similar thread: https://supportforums.cisco.com/thread/2096090
Sweta
Ok, thank you for verifying this info Sweta.
To make sure that the switch in the production remains the master... can I just set higher priority on it and lower priority on the new member? Or should I provision new member on the production switch? What's the best approach?
thanks,
lukasz
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
You could set switch priority, but stack master shouldn't change just adding a switch to the stack.
