Stackwise limitation
ajay kondapalli
Level 2
Level 2
What is the maximum number of switches can be stacked in stackwise technology. Is it 4 or 8 ?
Ajay
Sandeep Choudhary
HI Ajay,
Depends on what you need to do. You could connect 16 or more switches and have a total of 256 or more ports. But if your WAN connection to the first switch is to a 1Mbps DSL modem you are going to have quality of service issues.
The more you daisy chain switches...the worse the performance can be. Technically it can work to daisy chain more switches than you'll have available IPs...but it's an arguement of what sort of performance you're expecting, or even capable of determining.
just an example of stacking.
http://www.excitingip.com/1297/stacking-network-switches-lan/
Please rate if it helps.
Leo Laohoo
Stackwise comes in two "flavours".
The 2960S can be stacked UP TO four 2960S together to form a single logical unit.  The 2960S backplane has a 10 Gbps (full duplex) speed and uses a different stacking cable not compatible to the 3750/G/E/X.
The 3750/G/E/X can be stacked up to 9 units together to form a single logical unit.   3750/G has a stacking backplane speed of 8 Gbps (full duplex) vs 64 Gbps (full duplex) of the 3750E/X.  You can mix both any models of the 3750/G/E/X together because they are using the same stacking cable (that is not compatible to the 2960S) but by doing so it will bring the stacking backplane speed down to the lowest common denominator, 16 Gbps (full duplex).
Although it's been noted that you can stack up to nine (9) 3750/G/E/X together to form a single stack unit, it's not recommendable to have seven (7) or more units in a stack.
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Just to clarify Leo's information, the non-E/X have dual 8 Gbps (duplex) stack cables and the E/X have dual 16 Gbps (duplex) stack cables.  The E/X, besides doubling the bandwidth, uses its bandwidth much "smarter".  As Leo also notes, you can mix any series 3750 in the same stack, but any non-E/X will run the stack in non-E/X mode.
Thanks for the pickup Joseph.
