Static Default route redistribute into OSPF
Adnan Khan
Level 4
Level 4
Hi I want to redistribute statc default route into OSPF in Nexus 7706 but its asking through routemap?
can anyone give the syntax how i can redistribute default static route into ospf
ip route 0.0.0.0 0.0.0.0 192.168.1.1
8 Replies 8
Adnan Khan
Level 4
Level 4
do I also need to create access list and if yes what will be the syntax for this too?
the below should do it:
ip prefix-list DEFAULT_PREFIX seq 5 permit 0.0.0.0/0
route-map DEFAULT_RM permit 10
match ip address prefix-list DEFAULT_PREFIX
router ospf 1
redistribute static route-map DEFAULT_RM
Thank a lot Georg for quick reponse. Could you share the link form Cisco document for the same also
is "default information originate" can aslso work to advertise static default route into OSPF?
Yes, But I dont know about NEXUS, talking about normal router, it would generate default route to OSPF but only if it has default route in the RIB
but you can use #default-information originate always
I checked Default information originate command is available in Nexus under router ospf process so this can redistribute default static route in to ospf routing.
No, default information will send 0.0.0.0 route to OSPF neighbors, it will not redistribute it....
Hi Georg,
Could you please advice is default information originate always will propogate the default route in OSPF domain in Nexus 7706?
