Static Route per VLAN
jhydml
Visitor
Hi! Does anyone know here what is the command for these tasks?:
  • Configure static routing on HQ with route summarization to VLAN 10, 20, 30 and 40. Identify and configure all other remote networks of HQ.
  • Configure static routing on R1 with route summarization to VLAN 50, 60, 70 and 80. Identify and configure all other remote networks of R1.
  • Configure static routing on R2 with route summarization to VLAN 10, 20, 30 and 40. Identify and configure all other remote networks of R2.
  • Configure static routing on MSw with route summarization to VLAN 10, 20, 30 and 40. Identify and configure all other remote networks of MSw.
here is the revised lab. I added the static routes (192.168.0.0/17 and 172.168.0.0/22). There was also a lot of other stuff missing, like IP addresses on interfaces and administratively shut interfaces. I cannot test end to end connectivity because the user tabs on all your switches and PCs are locked. On R2,  think you also need to creare subinterfaces similar to R1.
Georg Pauwen
it is hard to see the IP addresses of the VLANs...can you post the Packet Tracer project file (.pkt) ? Make sure to ZIP it first, otherwise the system won't let you upload the file...
Hi! These are the Ip addresses...or should I really upload the topology?
