Storm Control question
redsector
Level 8
Level 8
I can set a Storm Control on Switch > Switch Settings and the rules.
I also can switch on Storm Control on the switchports MS210, MS225 etc. (enabled / disabled).
Does anybody know if there is an relationship?
Does the rules only work when I switch on the Storm Control on the ports?
Thank you.
BrechtSchamp
Level 11
Level 11
When you add at least one rule in the "Switch settings" rules, then the per port enable/disable option becomes available. Basically it allows you to make exceptions to the general storm control rules for specific ports.
5 Replies 5
MarcP829
Level 9
Level 9
can´t see it on MS120 :S
Model is not lsited here... Can you really see that for the MS120 on switch ports ?
https://documentation.meraki.com/MS/Other_Topics/Storm_Control_for_MS
It isn't supported on the MS120. See the datasheet:
image.pngMS210
image.pngMS120
BrechtSchamp
Level 11
Level 11
Nash
Level 11
Level 11
It's worth noting that there's a basic level of storm control present on all Meraki switches. The configurable version is only available on firmware versions 10.0 and higher, but not available on the 120 line.
redsector
Level 8
Level 8
BrechtSchamp was right.
I checked it out:
Based on MS11.22 firmware; MS225, MS210 switches:
First you have to enable Storm Control in "switch" -> "switch settings" by adding a rule.
Then you have an additional "Storm Control" setting in the switchports (not on the MS120 and MS220 switches!)
best regards.
