STP portfast and 802.1q
ricardoccnp2005
Hi guys,
Is there anyway to use both "spanning-tree portfast" and "switchport mode trunk" at the same time at the same interface ?
I did the config but I did not get the expected result ! As you can see at the configs below, I?ve configured two ports:
fa0/1 = portfast + trunk 802.1q
fa0/2 = portfast just
interface FastEthernet0/1
switchport trunk native vlan 22
speed 100
duplex full
interface FastEthernet0/2
switchport access vlan 21
switchport mode access
speed 100
duplex full
The results of show spanning-tree shows that the first port has not became an Edge port, but second one yes !
Interface Role Sts Cost Prio.Nbr Type
Fa0/1 Desg FWD 200000 128.64 P2p
Fa0/2 Desg FWD 200000 128.65 Edge P2p
Does anyone have a clue about what is happening here ?
Thanks a lot,
Ricardo
Use the command "spanning-tree portfast trunk"
