Strange performance issue
lgijssel
Level 11
Level 11
One of our customers currently experiences a strange performance issue. Basically, the problem is that the transfer of large files is slow when retrieving a large file from a server (Win2k3)that is connected on a gigabit interface to a workstation (Win-XP) on fast ethernet. For example a 130MB file can be uploaded in appr 12-15s, downloading it from the server takes about twice as long (31s).
The customer has all his servers attached to a 3750-stack, the workstations are on 3560-switches and the core is a redundant 6500. The exact network topology does not seem to make much difference though; I am also able to reproduce it on the 3750 stack by forcing a port to 100Mb and attaching a workstation to it.
There are no duplex mismatches in the network and the MTU size is 1500 for the whole network. Also, the gig-link on the server was not loaded, we used a dedicated testserver for our tests. Fiddling with the server's registry only produced worse results.
In the troubleshooting process, I already upgraded the IOS version of the 3750's from 12.2.25 to 12.2.40 but this made no difference. Also, the complaints have started after we installed the 3750 stack.
To add to the weirdness of this, the customer reported that the problem was not present on workstations running Vista or Linux. That was where I stopped investigating a month ago and I considered the issue a non-Cisco problem. Unfortunately we have just been informed that the problem is also absent when the switch is a 3Com instead of a 3750. My impression is that it might be related to packetbuffering but I find the issue very hard to troubleshoot.
I will go to the customer next week to make some traces but any input from anyone of you is highly appreciated.
Leo
11 Replies 11
graemeporter
Level 5
Level 5
Might this be to do with QoS (Quality of Service / packet shaping)? It's a possibility if your customer uses IP Telephony.
If QoS is implemented incorrectly, then there may be less bandwidth available for data on certain ports, with the remainder being reserved for voice traffic.
Additionally, if there are two VLANs involved, then the router may be configured to perform packet shaping in one direction; if the device that IS able to download quickly from the server happens to be on the same VLAN as the server, the packets might not hit the router, so no packet shaping - whereas the devices which take twice as long to download from the server are not on the same VLAN as the server, the packets must go through the router, and may be subject to packet shaping there.
Basically, I don't know for sure - but it sounds like a plausible cause for this problem, in my head at least 🙂
Hope this is of some help to you - let me know how you get on.
Kind regards
Graeme
Found it hard to capture all that has already been done about this in the first message.
QoS is not enabled on the 3750 switches and still we can reproduce the issue there.
Packet shaping is not configured here either, nor in the rest of the network.
The servers are largely in vlan 16, the test-pc was in the citrix-vlan (2). Be aware that the Citrix servers (on gigabit links) do not have any performance problems.
This is the vlan config of the 3750, pretty basic stuff I think:
interface Vlan1
description ILO & mgmt
ip address 172.23.8.254 255.255.255.0
ip helper-address 172.23.1.3
ip helper-address 172.23.1.1
ip helper-address 172.23.1.2
interface Vlan2
description Citrix
ip address 172.23.2.254 255.255.255.0
interface Vlan3
description GIS
ip address 172.23.3.254 255.255.255.0
interface Vlan4
description SRV-PA
ip address 172.23.4.254 255.255.255.0
interface Vlan16
description SRV01
ip address 172.23.1.254 255.255.255.0
interface Vlan104
ip address 172.23.255.6 255.255.255.252
interface Vlan108
ip address 172.23.255.10 255.255.255.252
interface Vlan112
ip address 172.23.255.14 255.255.255.252
interface Vlan116
ip address 172.23.255.18 255.255.255.252
vlan 104 - 116 are the layer3 uplinks to the coreswitches. Load balancing is performed by cef and currently we are allowing only two links to carry the traffic to/from the core. Using only one link did not give any improvement.
VoIP is not used here. There is some QoS in the network but this is merely to trust traffic from one particular port that is not yet in use. Still, I will test if it makes any difference when this is disabled. Keeping you posted!
regards,
Leo
Check for drops at the ASIC level which could be one of the cause
The commands sh platform pm if-numbers & sh platform port-asic stats drop asic will tell you this
You might have to tune your interface queues based on this
Narayan
On a most ports of the 3750, all counters are zero, a few have higher numbers but they do not increase when viewing them a second (or third) time.
The figures were aggregated over a running period of 3 months so this does not seem to me as a large number.
This was the highest counter:
L34AM#sh platform port-asic stats drop asic 9
Port-asic Port Drop Statistics - Summary
RxQueue 0 Drop Stats: 0
RxQueue 1 Drop Stats: 0
RxQueue 2 Drop Stats: 0
RxQueue 3 Drop Stats: 0
Port 0 TxQueue Drop Stats: 20651
Port 1 TxQueue Drop Stats: 411918
Port 2 TxQueue Drop Stats: 0
Port 3 TxQueue Drop Stats: 815
QoS setting for the 3750 stack:
L34AM#sh mls qos
QoS is disabled
QoS ip packet dscp rewrite is enabled
On a random 3560 (= access-switch, we have about twenty of them) I get the result below:
sw41d21#sh platform port-asic stats drop asic 0
Port 0 TxQueue Drop Stats: 0
Port 1 TxQueue Drop Stats: 0
Port 2 TxQueue Drop Stats: 103701
Port 3 TxQueue Drop Stats: 135151
Port 4 TxQueue Drop Stats: 0
Port 5 TxQueue Drop Stats: 86154
Port 6 TxQueue Drop Stats: 84042
Port 7 TxQueue Drop Stats: 86836
Port 8 TxQueue Drop Stats: 0
Port 9 TxQueue Drop Stats: 0
Port 10 TxQueue Drop Stats: 78547
Port 11 TxQueue Drop Stats: 240202
Port 12 TxQueue Drop Stats: 0
Port 13 TxQueue Drop Stats: 0
Port 14 TxQueue Drop Stats: 304858
Port 15 TxQueue Drop Stats: 385277
Port 16 TxQueue Drop Stats: 4442
Port 17 TxQueue Drop Stats: 169403
Port 18 TxQueue Drop Stats: 28999
Port 19 TxQueue Drop Stats: 2424
Port 20 TxQueue Drop Stats: 184948
Port 21 TxQueue Drop Stats: 179587
Port 22 TxQueue Drop Stats: 119822
Port 23 TxQueue Drop Stats: 271323
Port 24 TxQueue Drop Stats: 18
Port 25 TxQueue Drop Stats: 120535
(output abbreviated)
sw41d21#sh mls qos
QoS is enabled
However, QoS is only there to preserve marked packets, no queueing mechanism is used.
Port 25 is likely int gi0/2:
sw41d21#sh queueing int gi0/2
Interface GigabitEthernet0/2 queueing strategy: none
This is a typical port-config, they are all like this:
interface GigabitEthernet0/2
description Stackport to sw40d21
switchport mode trunk
mls qos trust cos
And the uptime of this switch:
sw41d21 uptime is 27 weeks, 3 days, 20 hours, 56 minutes
regards,
Leo
When you enable QoS, the queues by default would get equally distributed into 4 queues and the traffic from the server might be overflowing one of them.
Is there a way you can just disable QoS for testing. If things improve we might try tuning the queues later on
Narayan
Something else to consider, even though you're not seeing the drop counters increment as you watch, the fact you have any drops counted at all indicates there has been transient congestion bad enough to overflow the queue. You might still have transient congestion which doesn't overflow the queue.
Why is this import? TCP will only hit full speed when its receive window is at least as large as the bandwidth delay product (BDP). Transient congestion, making transient delays, could slow effective TCP transfer rates if default TCP receive window isn't large enough.
Joseph W. Doherty
Many of the recent Windows TCP stacks, pre-Vista, adjust their TCP receive window based on the Ethernet port speed. Not enough information to declare this is the cause of your issue, but something to be aware of.
Guys, also thanks to your input we have reached breakthrough! Graeme, I have absolutely underrated your first response which was 100% on-target. I will make this up with you.
I have always thought that mls qos was needed to do things like trusting packet-markings which is why it was here in the first place.
We have ample bandwidth so the more complex challenges of policing and shaping are not at all needed here.
I have now managed to resolve the issue remotely just by removing the line "mls qos" from the config of the 3560 access switches!
Fact is that we still have QoS running on the 6500 core with identical settings. It appears that QoS is handled very differently on differing platforms. I did know that this was the case but still the implications of having this single line in the config -without any policiers or other settings in place- strikes me as vague and weird. It certainly looks like I have some additional reading to do on the subject at which I felt quite comfortable.
Leo
What you are seeing is detailed in Bug CSCsc96037. This isn't a bug as such, but the default behaviour when QoS is enabled. Due to the way the hardware is, with the default egress queue settings you are seeing drops due to thresholds being reached when QoS is enabled. The code was modified in 12.2(25)SEE1 and later to allow more of the common pool buffers to be used by each of the egress queues. You do however need to modify the configuration:
mls qos queue-set output 1 threshold X 3200 3200 100 3200
Where 'X' is the queue you want to change.
Andy
Thank you, I will check the bug description.
Removing qos entirely solved the problem for now but we will need this when qos needs to be turned back on.
Thanks a lot!
Leo
Thanks a lot!
Leo
