Stuck at switch: prompt
swa64211
Hey guys, I'm a beginner. While working on ESS 3300 switch, upon restart switch is stuck at switch prompt. There is no error message, just the following -
switch:
Initializing disk drivers...
SD Card is not present
Initializing file systems...
switch:
I tried to follow this procedure but it's not working.... it says boot command not recognized
Even basic commands like '?' ,'help' , 'dir' , 'boot' , etc are not being recognized
also if I press backspace the,"switch:" is also being erased
It'll really be very helpful for me if anyone can help..... thank you
Deepak Kumar
try with this command :
boot emgy0:<image-name>.SPA.bin
 If you are still getting error msg. Can you past a screen shot.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Thank you, @Deepak Kumar for replying
When I executed that command, I'm getting an error-
"boot" command not recognized
