Stupid Newbie Routing Question
john-huntington
I do a lot of work with switched, private networks (for industrial control), but very little with routers.  I'm trying to pass the CCNA but failed the routing parts.  So, my friend gave me an old 3600 router, and I'm using a SGE-300 switch running CLI and then a stack of SG-2000P small business switches to learn this stuff.
I have them configured like this:
SGE2000P switch stack with a number of hosts on VLAN1, which has an IP address of 192.168.111.1/24
Connected to:
Ethernet0/0 of the 3600 router, with an IP address of 192.168.111.201 /24
Ethernet0/1 of the 3600 router, with an IP address of 10.0.0.1/8
Connected to:
SGE300 switch with a host on VLAN1, which has an IP address of 10.0.0.11/8
From the router, I can ping a host on the 192.168.111.0 network:
JohnHRouter#ping 192.168.111.21
Sending 5, 100-byte ICMP Echos to 192.168.111.21, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
and, a host on the 10.0.0.0 network:
JohnHRouter#ping 10.0.0.111
Sending 5, 100-byte ICMP Echos to 10.0.0.111, timeout is 2 seconds:
But, I can't ping from the 192.168.111.21 host to the 10.0.0.111 host, or vice versa.
I can see the networks in the routing table:
JohnHRouter#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
C    192.168.111.0/24 is directly connected, Ethernet0/0
C    10.0.0.0/8 is directly connected, Ethernet0/1
I added a command for "IP Routing", and here's my running-config file:
JohnHRouter#show run
Building configuration...
Current configuration : 736 bytes
version 12.4
hostname JohnHRouter
boot-start-marker
boot-end-marker
enable secret 5 $1$i/yi$RvUjMsZiX1pq1G/eiuHWG/
enable password notused
no aaa new-model
ip cef
no ip domain lookup
controller T1 1/0
framing sf
linecode ami
interface Ethernet0/0
ip address 192.168.111.201 255.255.255.0
half-duplex
interface Serial0/0
no ip address
shutdown
interface Ethernet0/1
ip address 10.0.0.1 255.0.0.0
half-duplex
ip http server
ip forward-protocol nd
control-plane
gatekeeper
shutdown
line con 0
line aux 0
line vty 0 4
password cisco
login
end
I tried adding a "router RIP" command but that didn't work either.
I'm sure this is some stupid thing I'm missing.  Any suggestions?
Thanks!
John
Jon Marshall
John
On the hosts have you set the correct default-gateway ie. the corresponding IP address on the router interfaces ?
Jon
6 Replies 6
john-huntington
Oh and I forgot to mention that I tried to establish static routes, but they either didn't seem to do anything, or gave me an error like  "can't use an IP address on this router".
Thanks!
John
You don't need static routes or RIP because the interfaces are directly connected to the routers. You only need static routes or a dynamic routing protocol if you want to exchange routes with another L3 device.
Jon
Jon is absoulutely right, you don't need any routing here. All you need is correctly configure your hosts (network\mask\gateway).
-GRinch
Jon Marshall
John
Jon
That's my second Homer-Simpson D'Oh! of this process, thanks!  I had the default gateways still set to the management addresses of the VLAN's in the switch.  I changed that and it worked fine!  Now I'll try to add another router and get a protocol going.
Thanks!!!
John
John
We all have those moments, you should see some of the ones i have had
Glad you got it working and thanks for the rating.
Jon
