01-30-2012 02:57 AM - edited 03-07-2019 04:37 AM
Dear all,
I have 2 ,WS-SUP720-3B ilnstalled in 6509 and one failed,.Can i replace this one with WS-SUPT20-3BXL ???Both ups are in the same machine.
01-30-2012 04:48 AM
As fare as I know the XL part i only that the card has more memory that a non XL.
They should work together
01-31-2012 03:34 AM
Thanks Claus for the reply
01-31-2012 05:50 AM
I am sorry to say that Cisco requires for redundancy to be supported the supervisor engine, the routing engine, and the forwarding engine models must be same on both Sup720 modules. While WS-SUP720-3B uses PFC3B forwarding engine WS-SUP720-3BXL includes PFC3BXL forwarding engine. As for the Cisco rules you cannot use one type of PFC (PFC3A, PFC3B or PFC3BXL) on one supervisor engine and a different type on other supervisor engine for redundancy.
Best regards,
Antonin
01-31-2012 05:53 AM
Correct. I was to fast...
Sorry.
