Sup engine MSFC card
gilbertthor
Wanna ask that in 6509e chasis, install with the 2 unit sup2 module which do as redundancy.
So with the "Sh Module" command in CAT OS, will it show 2 unit of MSFC card?
-Gilbert
mahmoodmkl
Level 7
Level 7
It will show both as 15 and 16.
Mahmood
hi,
So if i show module but not able to see the module 16 means the MSFC card might be failure right?
by the way , thks for u reply.
-Gilbert
