SUP Redundancy - mode sso
opers13
Our hot standby SUP crapped out last night and we already got a replacement from Cisco.
Now, after I insert the replacement hot standby, what excatly should I do?
Looks like I will have to copy the IOS from the Active SUP to hot standby SUP.
How about configuration? If I type "sh run module 8"  I see the config for the uplink interface only.
Does it mean the Active SUP actually handles the running and startup configs between SUPs??
thanks
Reza Sharifi
thanks
In order for SSO to work you have to have the same exact software on both Sups.
Configuration information and data structures are synchronized from the active to the redundant supervisor engine at startup and whenever changes to the active supervisor engine configuration occur. Following an initial synchronization between the two supervisor engines, SSO maintains state information between them, including forwarding information.
Have a look at config guide:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/nsfsso.html#wp1097378
Reza
