sup status led orange. Why?
alessandro.dona
Level 3
Level 3
Hi to all.
I have a 4006 with:
Supervisor III 1000BaseX (GBIC)
48 10/100BaseTX (RJ45)V
status led is orange but in the log there is nothing.
attached th sh env that looks to be ok!
any idea about this problem
6 Replies 6
Edison Ortiz
From the file you posted:
Chassis Temperature = 36 degrees Celsius
Chassis Over Temperature Threshold = 75 degrees Celsius
Chassis Critical Temperature Threshold = 95 degrees Celsius
_____________________________________________
36 Celsius seems a bit high operating environment and I believe that's the reason for the warning light being on.
Cisco says the led should go orange when Supervisor engine temperature sensor exceeds minor threshold (that is 75 Celsius)
Please post the output from typing
show test
and
show module
I checked your file again and :
PEM WS-X4095-PEM -- bad/off
This can also be causing the orange led.
JORGE RODRIGUEZ
Level 10
Level 10
hi, it could be your FAN, please so
" show sys " and look at FAN status.
Jorge
Jorge Rodriguez
Friend,
The SuP shows orange if either one of the power supply or the Fan is switched off.
as per the logs, it seems either the fan or power supply is not working and hence you are seeing the orange light
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/hardware/installation/guide/78-14409-08/05trblsh.html
HTH, rate if it does
Narayan
