Sup2-2-GE
ryanhoibm
Level 2
Level 2
Does anyone know what is the packet per second threshold for sup2-2ge?
The data sheet states it can run up to 30mpps. How to calculate this in production network?
6 Replies 6
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
15 Mpps, for whole chassis, when using non-fabric line cards.
30 Mpps, for whole chassis, when using fabric line cards (requires switch fabric module too).
Packet Size (Bytes)               64      128      256      512      1024      1518
Theoretical Maximum Kpps  1488     845      453      235        120         81
Above is for half-duplex.
Hi Joseph,
Thanks for replying!
How do check if the cat6k is hitting 30mpps? is there any cmd to check this? or we have to add up all the ports mbps then convert them to pps to verify?
Disclaimer
Posting
Sorry, I don't know of an easy method to check "PPS" utilization.  You could, as you note, check total bps (or fabric utilization) throughput while comparing to total CPU utilization (don't forget DFCs CPU too).
glen.grant
  A "show system" will give current traffic and when the peak utilization was. Won't be in packets per second though.
Hi Glen thanks!!!
Hi Joseph Thanks too!
CATOS command?
