Sup7-E and Sup 720
rajesh.rajappa
I am looking for options to upgrade the existing Cisco 4507R switch to a higher end model. The options I have considered is
1) Cisco 4507R+E with Sup 7-E
2) Cisco 6509-E with Sup720
But in the backplane capacity , the Sup 7-E shows as 848 Gbps and Sup 720 shows as 720 Gbps. Is my understanding correct ?
Any Suggestions
5 Replies 5
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind.  Usage of  this posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Correct.
re: suggestions:
There's more to consider than just fabric bandwidth.  From a performance perspective, there's also bandwidth to particular cards and/or card ports.  There's also PPS performance.  There's IOS features.  Lastly, there's also what your card options are.
PS:
To get the full performance out of the latest 4500 components, you might not want to reuse any current components.
Leo Laohoo
VS-Sup2T coming out next month.
rajesh.rajappa
Thanks All...
If I am not planning to use any service modules and only gigabit line cards, is it a good option to consider 4507R+E with Sup7-E rather than going with 6509-E with Sup720 ?
Am thinking from the cost perspective also..Please suggest
If cost is a concern it would be better to go with 4507R+E with Sup7-E. In fact this combination would give you more per slot bandwidth than 6500. 4507R+E with Sup7-E will give you 48 Gig/slot , nonblocking Gig port while using a 48 port gig module. 4748 modules are mandatory for 48 gig/slot bandwidth.You would save approx 20-35 % cost as well.
WS-X4748-RJ45-ECatalyst 4500 E-Series 48-Port 10/100/1000 Non-Blocking
Johny
rajesh.rajappa
Thanks Guys for the suggestions!!!
