SUP720 back to RP rommon mode after booting completely
Hele Du
Hi Experts,
Have a good day.
I encountering a SUP720 issue which is back to rommon mode after booting completely and stuck in Rommom mode.
For my opinion, I guess this is a hardware issue because this happen after customer`s electricity interruption.
But from the "logging" I found it notice “Possible software fault”.
Does anyone can confirm this issue is hardware or software?
Unfortunatly you really need flash card on Sup720 it does not support xmodem like standard switches, you can pick up a generic one pretty cheap and format it.
Cisco
As the Recover a Supervisor Engine 720 from a Missing/Corrupted Cisco IOS Image or ROMmon Mode section mentions, the Supervisor Engine 720 does not support the Xmodem recovery procedure.
Therefore, always keep a copy of the image in disk0 or disk1, or the MSFC boot Flash. If you do not have any copies on either disk0 or disk1 and you encounter the problem of a missing/corrupted image, the only way to recover is to copy the image on the Flash disk from another switch.
9 Replies 9
Mark Malone
so this really should go to TAC as it produced a crash file from the output, should be in your flash that will contain a lot of info , power surge could easily corrupt software or hardware or both
The problem with that output is some platforms will report a software failure like that even if its hardware fault especially if its been rebooted
Is there only 1 image on the switch or can you boot another one from rommon to rule of the software ?
Can you get the switch back online at all  , the show stacks of that effected switch that crashed and if you have the crash file it may show something , crash file should be still retrievable either way
If you have support on this device you should TAC it as they have specific tools for reading crash reports that non Cisco staff do not have access to and if you have hit a bug that's unknown only they will be able to tell you through the DE team
At the time of bootup, a router can detect that a Cisco IOS software image is corrupt, return the compressed image checksum is incorrect message, and attempt to reload. In this case, the event is reported as a software-forced crash.
Error : compressed image checksum is incorrect 0x54B2C70A
        Expected a checksum of 0x04B2C70A
*** System received a Software forced crash ***
signal= 0x17, code= 0x5, context= 0x0
PC = 0x800080d4, Cause = 0x20, Status Reg = 0x3041f003
A software-forced crash occurs when the router detects a severe, unrecoverable error, and reloads itself so that it does not transmit corrupted data. A vast majority of software-forced crashes are caused by Cisco IOS® software bugs, although some platforms can report a hardware problem as a software-forced crash.
HI Mark,
Thank you for your response.
Actually,this switch is out of service.
This switch cannot boot up, it always stuck in rommon mode.
Is there have a way to upload another image and boot from it in rommmo mode?
I read this document before(Recovering a Catalyst 6500/6000 Running Cisco IOS System Software from a Corrupted or Missing Boot Loader Image or ROMmon Mode,http://www.cisco.com/c/en/us/support/docs/switches/catalyst-6000-series-switches/17050-14.html#Sup720),it says that insert another disk and boot from that disk to recovery. I do not have a Cisco CF card......
Cisco
Hi Mark,
I found a Cisco 256MB CF card and uploaded a SUP720 image in it...
I will try this method after Chinese Spring festival holiday.
Happy Spring festival!
So they say to use only Cisco CF cards  ?  If not got around it before by formatiing generic card to FAT16 that may work for you worth a try if you have no others there , or else if you have another 6500 with a CF card borrow that as they don't need one to run it live,only at reboot is the CF used
http://www.cisco.com/c/en/us/td/docs/routers/access/1800/1841/software/configuration/guide/sw/b_cflash.html
HI Mark,
Sorry for delay response.  These days are Chinese new year, Happy Chinese new year.
This SUP720 can identify this CF card to disk0 after fully booting, but it can not identify this CF card in RP rommon mode.
It isn`t as same as this document said.
Directory of disk0:/
    1  -rw-    64301664   Feb 7 2000 15:47:00 +00:00  ubr7200p-jk9su2-mz.122-33.SCG6.bin
    2  -rw-     8746512  May 24 2006 12:50:38 +00:00  ubr7200p-kboot-mz.122-33.SCA.bin
    3  -rw-       19686   Feb 7 2000 15:47:08 +00:00  running-config
    4  -rw-   145281892  Feb 21 2000 05:10:42 +00:00  s72033-adventerprisek9_wan-mz.122-33.SXJ10.bin
rommon 8 > dir disk0:
bad device name (Device not supported)
usage: dir <device>
rommon 9 > dev
Devices in device table:
        id  name
bootflash:  boot flash
    slot0:  PCMCIA slot 0
    eprom:  eprom
I experienced exactly the same problem. On 15 of my 6500's. After power surge your 6500 boots in ROMMON. Al having SUP720 modules. So you issue the command "boot" from console and it will boot. Checked the config register and it was correct 0x2102 for the RP after boot. I power cycle it and it was back in ROMMON. I set the config register of the switch part I believe then in ROMMON and power cycle it, and it boots fine. Power cycle it 2 times then, fine both times. One month later I was back. Power surge and config register had to be set again. After number 4 , I replaced the SUP720 and I never had to go back again.
In my office I tried to simulate this problem with the power switch on the "faulty 720". switching it off at different times. It never went into ROMMON again. So to simulate it, I could not get it to ROMMON again. In the field, it gives you problems.
I have sites with 10 x 6500's installed of which 8 went into ROMMON the same time, after a power surge. The one I replaced with a never version 720, is running now for 2 years without a ROMMON failure. The others we still needed to drive out and set the registers every now and then.
I changed employment recently, (New Country) and they have exactly the same issue.
Do you know of a TAC number for this possible?
Johan
Hi Johan,
Actually, we had RMA the supervisor.
The TAC told me this is maybe a hardware or software issue, the best way to fix this is RMA.
HI Mark,
I try to that method, but the switch can not recognize that CF card.
I mean that it can not display a partition called disk0,disk1 or slot0.
monitor: command "no" not found
rommon 7 > boot
loadprog: bad file magic number:      0x0
boot: cannot load "bootflash:"
usage: dir <device>
rommon 9 > dev
        id  name
    eprom:  eprom
rommon 10 > set
PS1=rommon ! >
LOG_PREFIX_VERSION=1
I pretty sure that CF card can work. If I am using a dir in this switch before carsh, it can display a partition called disk0.
Router#
*Feb  6 08:14:22.245: %FABRIC-SP-5-CLEAR_BLOCK: Clear block option is off for the fabric in slot 5.
*Feb  6 08:14:22.245: %FABRIC-SP-5-FABRIC_MODULE_ACTIVE: The Switch Fabric Module in slot 5 became active.
Router#
Router#
Router#dir
261083136 bytes total (42725376 bytes free)
Router#show ver | in IOS
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVENTERPRISEK9_WAN-M), Version 12.2(33)SXI3, RELEASE SOFTWARE (fc2)
Router#
%Software-forced reload
