Supernet question
marcusbrutus
Hi. I was just analyzing the concept of using VLSM and supernetting and i was just a bit confused over some details.
Before anything else, if i have a subnet of 192.168.0.0/30 used for a pt. to pt. serial interface, can i assign a subnet of 192.168.0.0/28 on an e0 interface for example? If not, then shouldn't i just use a standard subnet of /28 instead? Meaning that i assign a subnet of 192.168.0.0/28 on the serial interface and 192.168.0.16/28 on the e0 interface.
Jon Marshall
No you can't use 192.168.0.0/30 and then 192.168.0.0/28 on different interfaces. But you can do
192.168.0.0/28 on the ethernet interface and then
192.168.0.16/30 for the P2P serial link.
This would not be a good example of using VLSM within a class C though.
For P2P links it's often best to start at the end of the subnet range and work backwards ie.
192.168.0.0/28 for ethernet interface
192.168.0.252/30 for serial interface.
This gives you more flexibility in splitting up the class C network.
Jon
Jon Marshall
Jon
