09-28-2012 09:19 AM - edited 03-07-2019 09:10 AM
Hello, I have a switch WS-C3750E-48PD, I had two cameras that use 15.4 W in these ports and two days ago these ports go down, now the ports don't deliver PoE but are good when connect a computer.
I show some outputs that can help.
SWP-D302-1-1#show power inline
Module Available Used Remaining
(Watts) (Watts) (Watts)
1 800.0 64.0 736.0
SWP-D302-1-1#show runn inter gi1/0/9
Building configuration...
Current configuration : 223 bytes
interface GigabitEthernet1/0/9
switchport access vlan 2007
switchport mode access
switchport port-security maximum 10
switchport port-security violation restrict
spanning-tree portfast
end
SWP-D302-1-1#
SWP-D302-1-1#show runn inter gi1/0/10
Current configuration : 224 bytes
interface GigabitEthernet1/0/10
end
SWP-D302-1-1#show power inline gi 1/0/9
Interface Admin Oper Power Device Class Max
(Watts)
Gi1/0/9 auto off 0.0 n/a n/a 15.4
Interface AdminPowerMax AdminConsumption
(Watts) (Watts)
Gi1/0/9 15.4 15.4
SWP-D302-1-1#show power inline gi 1/0/10
(Watts)
Gi1/0/10 auto off 0.0 n/a n/a 15.4
(Watts) (Watts)
Gi1/0/10 15.4 15.4
Thanks for the help.
09-28-2012 09:22 AM
Hello Adrian,,
Can you post the output of show post
regards
Harish
09-28-2012 11:55 AM
Hello Harish, here you are the output.
SWP-D302-1-1#show post
Stored system POST messages:
Switch 1
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: MA BIST : Begin
POST: MA BIST : End, Status Passed
POST: TCAM BIST : Begin
POST: TCAM BIST : End, Status Passed
POST: SF ASIC BIST : Begin
POST: SF ASIC BIST : End, Status Passed
POST: Switch Fabric Memory Tests : Begin
POST: Switch Fabric Memory Tests : End, Status Passed
POST: CPU MIC interface Loopback Tests : Begin
POST: CPU MIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
POST: Inline Power Controller Tests : Begin
POST: Inline Power Controller Tests : End, Status Passed
POST: Thermal, Fan Tests : Begin
POST: Thermal, Fan Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
POST: EMAC Loopback Tests : Begin
POST: EMAC Loopback Tests : End, Status Passed
SWP-D302-1-1#
I have a question I am not sure if the output of this command is the result of the last POST when the problem doesn't exist and I didn't restart the device after the problem because is a production switch.
Thanks.
09-28-2012 12:35 PM
Yes Thats a good thought as this output shows the inline controller is passed the post.. Why dont we restart the switch and see the problem gets resoved or get a new post which says the problem with inline controller if any
Harish.
10-03-2012 06:04 AM
Hello, this is the output of the show post command after restart the switch.
Switch 1
Thanks.
