05-20-2018 12:23 AM - edited 03-08-2019 03:04 PM
Good morning.
I have 2 switches Type 3650 one has 24 ports the second has 48 port. additional each switch has 4 slots for g-bic modules. 2 gigabit and 2 ten gigabit.
I have to establish a connection via fiber optic from switch to switch as tengigabit via port TE1/1/4 on each switch.
A router 2911 is working as dhcp server and dns, its connected to one of the "normal" 1gb ports of the first switch.
On that switch i get ip address and internet access on a connected client. But i don´t get access to the web interface of the switch. Everything is on factroy defaults and initial config is not done. So in my opinion i should get access to the web interface using the default user name and pw, but the web inferface deny access.
Here is the confit of switch no1 ( 24 port)
Switch#show running
Building configuration...
Current configuration : 6796 bytes
! Last configuration change at 12:14:35 UTC Wed May 9 2018
version 16.6
no service pad
no platform punt-keepalive disable-kernel-core
hostname Switch
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
--More--
May 9 12:14:39.400: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Config Wizard) no aaa new-model
switch 1 provision ws-c3650-24pd
cpp system-default
diagnostic bootup level minimal
spanning-tree mode rapid-pvst
redundancy
mode sso
class-map match-any system-cpp-police-topology-control
description Topology control
class-map match-any system-cpp-police-sw-forward
--More-- description Sw forwarding, L2 LVX data, LOGGING
class-map match-any system-cpp-default
description DHCP Snooping, EWLC control, EWCL data
class-map match-any system-cpp-police-sys-data
description Learning cache ovfl, Crypto Control, Exception, EGR Exception, NFL SAMPLED DATA, Gold Pkt, RPF Failed
class-map match-any system-cpp-police-punt-webauth
description Punt Webauth
class-map match-any system-cpp-police-l2lvx-control
description L2 LVX control packets
class-map match-any system-cpp-police-forus
description Forus Address resolution and Forus traffic
class-map match-any system-cpp-police-multicast-end-station
description MCAST END STATION
description Transit Traffic and MCAST Data
class-map match-any system-cpp-police-l2-control
description L2 control, FSS
class-map match-any system-cpp-police-dot1x-auth
description DOT1X Auth
class-map match-any system-cpp-police-data
description ICMP redirect, ICMP_GEN and BROADCAST
class-map match-any system-cpp-police-control-low-priority
--More-- description General punt
class-map match-any non-client-nrt-class
class-map match-any system-cpp-police-routing-control
description Routing control
class-map match-any system-cpp-police-protocol-snooping
description Protocol snooping
policy-map system-cpp-policy
class system-cpp-police-data
police rate 600 pps
class system-cpp-police-sys-data
police rate 100 pps
class system-cpp-police-sw-forward
police rate 1000 pps
class system-cpp-police-multicast
police rate 500 pps
class system-cpp-police-multicast-end-station
police rate 2000 pps
class system-cpp-police-punt-webauth
class system-cpp-police-l2-control
police rate 500 pps
class system-cpp-police-routing-control
--More-- police rate 1800 pps
class system-cpp-police-control-low-priority
police rate 200 pps
class system-cpp-police-l2lvx-control
class system-cpp-police-topology-control
police rate 13000 pps
class system-cpp-police-dot1x-auth
class system-cpp-police-protocol-snooping
class system-cpp-police-forus
class system-cpp-default
--More-- !
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip address
shutdown
speed 1000
negotiation auto
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
--More-- !
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
--More-- interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface TenGigabitEthernet1/1/3
interface TenGigabitEthernet1/1/4
interface Vlan1
--More-- no ip address
shutdown
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
control-plane
service-policy input system-cpp-policy
no vstack
line con 0
stopbits 1
line aux 0
stopbits 1
--More-- line vty 0 4
login
line vty 5 15
login
end
05-20-2018 01:46 AM
how do you access the web interface ? I don't see an IP address configured on your switch:
interface Vlan1
no ip address
shutdown
05-20-2018 02:48 AM
i know the ip for the switch supplied by the router, because when i start i follow this sequence.
- Start router
- if its up, start switches ( so the switch gets the first address out of the dhcp address pool. (10.0.130.31)
- connect client PC to the switch ( it gets the second address from the dhcp address pool.(10.0.130.32)
then i have internet connection via switch and router.
then i use the browser on the client computer input switch address (http://10.0.130.31) and the switch login appears on on the browser... i input the factory defaults (admin/cisco) and get acces deny because of wrong pw and/or user name.
05-20-2018 02:55 AM
you have configured local authentication:
Unless I missed it, I don't see a local username and password. Try and configure
username admin privilege 15 password cisco
05-20-2018 04:16 AM
if you are sayinig your switch gets an IP address through dhcp (you might want to change that and stick a static ip address on).
your ip http server is on. you would need to define a local user name priv 15 password 0 <password>
cos otherwise it cant authenticate
05-27-2018 10:30 AM
Ok now i had access to the web interface ...but after basic setup and set a new pw for web access, the switch restarted and i wasnt able to get access again... allways wrong password message ...and i am 100% sure that i input the right one wich i gave to the webinterface before. Or do i have to set the same pw via console to the router with user command privilege 15.
Also Factory reset doesnt work. (as described by pressing mode button) If i press mode button ...just the mode changes and noting else there is no blinking...nothing.
05-27-2018 11:04 AM
I am sure that you are facing typo issue with username or password.
Here is password recovery process:
Deepak Kumar
05-28-2018 08:52 AM
Thanks for the link. I will try this out tomorrow. I dont think that it is a typo issue because used really simple user name and password, because its just a test setup.
maybe i would not need the web interface to setup the switches basics. i just need both switches communicate via interface TE/4 and deploy dhcp, comming from a dhcp server connected to a lan port of switch no 1. i just thought its maybe more easy with the switch web interface. The switches i used before were not needed to be configured thatswhy i am a bit confused about this ones :)
Best regards
Ralf
