Switch 3750x-48PS
Stefanio38
Community Member
Hello guys,
'I new here in the Forum and would like to post my first question: Where I work, my client has 3 switches model 3750x-48PS connected via cable stack.
The problem is in the switch 3 of the stack the two doors giga3/0/21 and giga3/0/24, the phones don't register in the register, but when I ask for customer connect on another port or other switches in the stack, the phones register normally.
I did another procedure to give the command reload slot on the switch 3, the phones registered in ports that I mentioned above, but then lost the record. Has anyone got a similar problem? Know to report if there is a bug in these specific models?
Thank you in advance!
16 Replies 16
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
A properly functioning 3750X stack, functional behavior shouldn't vary just depending on which stack member you connect to.
What IOS version is being used?
Hi Joseph,
Thank you for the return! The IOS is version 15.0 (1) SE2
But details are in the attached file.
Do you have a maintenance contract and do you need 15x features?
I contacted Cisco and I was told that the agreement only covers replacement, as for example in the event of a failure. We have no right to the support engineer can do the troubleshooting.
So your maintenance contract doesn't support changing IOS versions?  (That's far different opening a TAC case.)
AllertGen
Level 8
Level 8
Hello, .
Is there any difference at the configuration between this problem ports and ports that works well? Does another devices works well at this ports? Is there any errors at this ports?
Best Regards.
Hi, AllertGen
The settings are the same for all ports on the switch and logs p just nothing out of the ordinary of the door are ranging from UP and DOWN, because I was testing along with the client. The problem is that when it connects to the phone on the doors giga3/0/giga3/0/21 and 24 no phone registers on this port. If I test on another port on the same switch or another switch of the stack the phones register normally.
If case is useful phones of Cisco IP model 6945, with firmware version 6945.9-4-1 CCP-3.
I'm sending you attached the configuration file
Both your Gi3/0/21 and Gi3/0/24 ports have hardcoded speed and duplex. Can you please configure both to "auto" and see if there is any progress.
Best regards,
Antonin
Hi.
I have done this test and had no effect no.
Hi.
Is there any errors by commands "show interface Gi3/0/21" and "show interface Gi3/0/24"?
Best Regards.
Hi, Allert,
There is no errors in both doors. This problem is very bizarre!
WSPSW05#show interfaces gigabitEthernet 3/0/21
GigabitEthernet3/0/21 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is 2894.0fc1.a815 (bia 2894.0fc1.a815)
  Description: --------------[CONEXAO COM USUARIO]
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 5d21h, output 2d21h, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     12119304 packets input, 3173328259 bytes, 0 no buffer
     Received 657602 broadcasts (259040 multicasts)
     0 watchdog, 259040 multicast, 0 pause input
     255026466 packets output, 63390961937 bytes, 0 underruns
     0 output errors, 0 collisions, 5 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
WSPSW05#
WSPSW05#
WSPSW05#
WSPSW05#show interfaces gigabitEthernet 3/0/24
GigabitEthernet3/0/24 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 2894.0fc1.a818 (bia 2894.0fc1.a818)
  Last input 5d21h, output 00:00:28, output hang never
  5 minute output rate 98000 bits/sec, 60 packets/sec
     2896986 packets input, 418050619 bytes, 0 no buffer
     Received 169905 broadcasts (78415 multicasts)
     0 watchdog, 78415 multicast, 0 pause input
     152189136 packets output, 35524874407 bytes, 0 underruns
     0 output errors, 0 collisions, 4 interface resets
WSPSW05#
The door 3/0/21 giga is down because I requested him to disconnect the ip phone. While the door giga3/0/24 I don't see coming CPD information in it. Possibly should be turned on any station, network printer or anything else that doesn't return CDP
Well, the last test that I can to offer is to put another device (not a phone) to this port and look how good it works. If there is problems as well than there could be damaged ports. If not than it's better to contact TAC if you (or your client) has a SmartNet contract.
Best Regards.
Thank you AllertGen.
My client said had more 3 ip phone lost register. I'll open a TAC on Cisco.
Could it be not a switch problem? For example could it be out of license or extension numbers at the phone server side?
Best Regards.
