switch command for two router
petercinvest
Level 4
Level 4
I have switch1 needs to connect to one non-cisco brand router (public IP: 202.101.98.3*) for internet access, which are the script I should put inside switch1 trunk port G1/0/6
I have switch2 needs to connect to one intranet cisco 19** router, which are the script I should put inside switch1 trunk port G1/0/11?
Ganesh Hariharan
Hi ,
First and basic thing is to have connectivity between the two devices.
Is natting is done at your internet router ? if yes then you need to configure and connect with internet router over point to point subnet over a vlan allowed under the trunk and do a default routing on your device. Check with internet router administrator that which subnet they have allowed for nat.
Trunk configuration
and same sort of concept is required for intranet connectivity.
Hope it Helps..
-GI
Rate if it Helpss
