Switch crashes after SPAN configuration
Alex Vector
I needed to configure SPAN on my Cisco IOL switch
But on creating the destination interface, as soon as I hit enter, the session gets disabled.
Switch(config)#no monitor session 1
Switch(config)#monitor session 1 source interface e0/1
Switch(config)#monitor session 1 destination interface e0/3
After this when I press ENTER, the session gets disconnected and the switch just reboots.
This is what I see while this happens
Switch#
Exception:
Frame pointer FFFFBA20, PC = 899F81D
LINUX-EXT-SIGNAL: U_SIGSEGV(11), Process = Sched
-Traceback= 0x899F81Dz
EAX = BE57B118 EBX = 0D3B2EF8 ECX = 54BAFFFF EDX = 00000000
ESP = FFFFBA20 EBP = FFFFBA88 ESI = 00000000 EDI = 18B157BE
EFL = 00010282 EIP = 0899F81D
CS = 0023 SS = 002B DS = 002B ES = 002B
FS = 0000 GS = 0063
Invalid path crashinfo_00083_20201006-190930-+03
Buffered messages:
*Oct 6 16:02:31.924: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Oct 6 16:02:32.233: %SYS-5-RESTART: System restarted --
...... (other logs)
Queued messages:Segmentation fault
The switch has its basic default configuration for all interfaces. Please help if you know what to do
Thanks and Regards,
Alex Vector
Reza Sharifi
Appears to be a software crash. I would open a ticket with Cisco and have them investigate the issue. You may need to upgrade the IOS.
