Switch doesn't connect to the PC.
benone
Hello guys.
I've managed to connect through internet via PPoe on my Cisco 1841 Router, I can ping my Cisco 2950 switch and vice versa and my switch can ping 8.8.8.8 with success, but I can't seem to find why my PC doesn't connect to the internet when I connect it through my switch.
I've tried to connect my PC with the router through the LAN ports of my router and it doesn't work as well. My PC is on DHCP auto, also I've tried giving it IPs manually with no success. ( + also tried release and renew / hardware reset to switch )
Here are my configs for both router and switch:
Switch:
Building configuration...
Current configuration : 1676 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname main_SW
enable secret 5 $1$QOT9$e4GDg/0/WshTnxrhTdYfh/
username beleaua secret 5 $1$P5Ln$BPbPwvzMwkyIG9uIEwq8P.
ip subnet-zero
ip domain-name cisco.com
ip ssh time-out 120
ip ssh authentication-retries 3
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
 switchport access vlan 2
 switchport mode access
interface FastEthernet0/2
interface FastEthernet0/3
 description PC_sufragerie
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
 no ip address
 no ip route-cache
 shutdown
interface Vlan2
 description ROUTER NETWORK VLAN
 ip address 192.168.1.10 255.255.255.0
 no ip route-cache
interface Vlan3
 no ip address
 no ip route-cache
 shutdown
ip default-gateway 192.168.1.1
ip http server
line con 0
line vty 0 4
 login local
 transport input ssh
line vty 5 15
 login local
 transport input ssh
end
Router:
Current configuration : 1897 bytes
version 12.4
hostname main_RT
boot-start-marker
boot-end-marker
enable secret 5 $1$8DZ4$S2FO4kIFwON9FLl6IHg6t.
no aaa new-model
dot11 syslog
ip cef
ip domain name cisco.com
username beleaua secret 5 $1$dzTV$Hov/xBIJwFlZfWzlvAsbi1
archive
 log config
  hidekeys
controller DSL 0
 line-term cpe
interface BRI0
 no ip address
 encapsulation hdlc
 shutdown
 description Ethernet connection
 no ip address
 no ip mroute-cache
 duplex auto
 speed auto
 pppoe enable group global
 pppoe-client dial-pool-number 1
interface FastEthernet1
 description SWITCH NETWORK
interface FastEthernet2
interface FastEthernet8
interface Vlan1
 no ip address
interface Vlan2
 description SWITCH NETWORK VLAN
 ip nat inside
 ip virtual-reassembly
 no ip mroute-cache
interface Dialer0
 description ISP PPOe config
 ip address negotiated
 ip mtu 1492
 ip nat outside
 encapsulation ppp
 ip tcp adjust-mss 1452
 no ip mroute-cache
 dialer pool 1
 ppp authentication pap callin
 ppp pap sent-username BB91838414 password 0 tTzb5eVbsB
 ppp ipcp dns request
 ppp ipcp route default
 ppp ipcp address accept
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer0 overload
access-list 1 permit any
dialer-list 1 protocol ip permit
control-plane
line con 0
line aux 0
line vty 0 4
 login local
 transport input ssh
line vty 5 15
 login local
 transport input ssh
end
Have a great day.
configure the switch as below : try again.
BB
balaji.bandi
what port is your Pc connected what is the IP address of the PC. i did not see any DHCP Configuration on either of the device,.
Configure your PC IP
IP 192.168.1.10
Mask : 255.255.255.0
gateway : 192.168.1.1
DNS 8.8.8.8
BB
Thanks for your response.
The port through which I connect my PC via switch is fa 0/7 , and I've tried to set the IP manually like you said, but it didn't work.
BB
Thanks a lot, I've made it work.
Have a great day.
