switch from Stack 2x C9200 removed
we have a switch sw1 in Stack 2x C9200L - went out the itself Stack.
we tried to change Stack cable and reload but no go.
no Configuration change and was ok for more than a year.
sw1#sh sw
Switch/Stack Mac Address : cc7f.761a.aaaa - Foreign Mac Address
Mac persistency wait time: Indefinite
H/W Current
Switch# Role Mac Address Priority Version State
1 Member 0000.0000.0000 0 V01 Removed
*2 Active cc7f.763e.aaaa 1 V01 Ready
what else we can try ?
Boris
2 Accepted Solutions
balaji.bandi
The switch not joining stack boot ? when you console and check ? - if that is booting ?
have you setup switch numbers and priorty of the switch to be master ?
what is the versios of CODE
Turn off both the switches, check the cables again. and Turn on Switch 1 first and then Switch 2 ? console to Switch 1 post complete logs.
BB
@BorislavPenchev0962 wrote:
16.09.05
I know what this is:  CSCvr32460
9200/9200L firmware has several "stack merge" bugs and this is one of those bugs.
The only way to fix this is to reboot the switch that is currently not joining.  If the switch is in ROMMON, it would be good to have a console into the switch before rebooting.  Post the entire boot-up process so we can have a look.
7 Replies 7
balaji.bandi
BB
sorry clicked accept solution by mistake, issue still persist
IOS 16.09.05
we can not reboot the master as its production environment, the member in question has been rebooted many times;
- "The switch not joining stack boot ? when you console and check ?" - how to check that ?
Switch/Stack Mac Address : cc7f.761a.aaaa- Foreign Mac Address
                                             H/W   Current
         Stack Port Status             Neighbors
Switch#  Port 1     Port 2           Port 1   Port 2
  2       DOWN       DOWN             None     None
Sw#/Port#  Port Status  Neighbor  Cable Length   Link OK   Link Active   Sync OK   #Changes to LinkOK  In Loopback
2/1        DOWN         NONE      50cm           Yes       No            Yes       6                   No
2/2        DOWN         NONE      50cm           Yes       No            Yes       1                   No
Redundant System Information :
       Available system uptime = 1 year, 8 weeks, 1 day, 14 minutes
Switchovers system experienced = 1
              Standby failures = 1
        Last switchover reason = active unit removed
                 Hardware Mode = Simplex
    Configured Redundancy Mode = sso
     Operating Redundancy Mode = Non-redundant
              Maintenance Mode = Disabled
                Communications = Down      Reason: Failure
Current Processor Information :
               Active Location = slot 2
        Current Software state = ACTIVE
       Uptime in current state = 44 weeks, 6 days, 22 hours, 32 minutes
                 Image Version = Cisco IOS Software [Fuji], Catalyst L3 Switch Software (CAT9K_LITE_IOSXE), Version 16.9.5, RELEASE
                          BOOT = flash:packages.conf;
        Configuration register = 0x102
Boris
pman
Maybe it's a BUG
https://quickview.cloudapps.cisco.com/quickview/bug/CSCvn30950
Workaround:
The only way to recover is to reboot the Active switch. Proactively perform a "redundancy force-switchover" about once a week.
Leo Laohoo
What is the exact IOS-XE version of the stack?
16.09.05
16.09.05
reboot of both switches one by one worked.
thanks !
