switch mode bundle
Anukalp S
Level 7
Level 7
Hi. Could you please confirm if below switch running in bundled or installed mode?.sh ver output dont display mode on the switch here.
Also please confirm if bootloader Version 16.6.2r[FC1] will support IOS Version 16.9.4 as we are planning to upgrade it from Version 16.6.4a to Version 16.9.4.
Cisco IOS XE Software, Version 16.06.04a
Cisco IOS Software [Everest], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 16.6.4a, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Fri 26-Oct-18 18:15 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2018 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: System Bootstrap, Version 16.6.2r[FC1], RELEASE SOFTWARE (P)
INDRCS01 uptime is 11 days, 10 hours, 20 minutes
Uptime for this control processor is 11 days, 10 hours, 22 minutes
System returned to ROM by PowerOn at 01:12:35 GMT Wed Nov 27 2018
System restarted at 02:55:32 GMT Thu Mar 14 2020
System image file is "bootflash:cat9k_iosxe.16.06.04a.SPA.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Technology Package License Information:
Technology-package Technology-package
Current Type Next reboot
network-advantage Permanent network-advantage
dna-advantage Subscription dna-advantage
cisco C9407R (X86) processor (revision V01) with 1916969K/6147K bytes of memory.
16.6.2r[FC1] should work fine.
Reza Sharifi
On the 9400 series "sh ver" does not show that. Use the "sh boot" command  instead. If the device is pointing to .bin than it is in bundle mode. If the device is pointing to packages.conf than it is in install mode.
Thanks Reza, sh boot show .bin, could also please confirm if i need to upgrade boot loader version also to upgrade IOS from 16.06.04 to 16.9.4, current bootloader version is 16.6.2r[FC1] OR will it auto upgrade.
INDRCS01#show boot
BOOT variable = bootflash:cat9k_iosxe.16.06.04a.SPA.bin;
Configuration Register is 0x102
MANUAL_BOOT variable = no
BAUD variable = 9600
ENABLE_BREAK variable does not exist
ROM: IOS-XE ROMMON
16.6.4a is a really, really old firmware.
