Switch model
Guys,
Can someone recommend me the Switch model which i can use at access layer to support 10G connectivity for my Server.
10 Replies 10
Seb Rupik
HI there,
A 3850 with a C3850-NM-2-10G o C3850-NM-4-10G  module.
If you want the NM-4-10G you need to pick a  48-port  3850.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3850-series-switches/datasheet_c78-720918.html
cheers,
Seb.
Any other model apart from 3850 Series as 3850 is quite expensive for my customer.
OK, the 2960X can support up to two SFP+ interfaces per chassis:
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-x-series-switches/datasheet_c78-728232.html
..or perhaps cheaper is a SG350X which on some models has up to four SFP+ interfaces:
https://www.cisco.com/c/en/us/products/collateral/switches/350x-series-stackable-managed-switches/datasheet-c78-735986.html
cheers,
Seb.
dbeattie
This depends on the whole requirement: one 10G server or a lot of them, in a Data Centre or a small office. Generally, aggregation of 10G servers works well on Nexus 93180 for SFP-based access or Nexus 93108 for copper-based access.
Hope this helps.
Dave
Customer only requiremnt is that is should be cheaper than 3850 series and customer need around switch which can support between 12-24 ports having 10G capability.
12-24 SFP+ ports and cheaper than a 3850? I don't this is possible.
Maybe a WS-C4500X-24X?
Mark Elsen
 https://www.cisco.com/c/en/us/products/switches/switch-selector.html
M.
Leo Laohoo
What is your budget?
If your customer just wants a Cisco logo and low price I don't think you'll get 24 SFP+ ports cheaper than on a SG350XG-24
cheers,
Seb.
