Switch not learning PC/Laptop MAC after connected to another switch
dvo73d123
Has anyone experienced this issue before, client originally connects to the 4500E, moves to the 2960s and then cannot connect back to the 4500E.
My design is a 4500E (configured for routing) and a 2960s. The 2960s is trunked to the 4500E, no vlan pruning.
Tried;
- shut/no shut port on the 4500E doesn't work
- no result for sh ip arp | i (clients mac) or sh mac address | i (clients mac) on the 4500E
The only way I can get the user back online is removing the 2960s, not a desirable solution as other clients are on the 2960s.
Milan Rai
Hey Matt what about the mac address notification change??????
have you configured this on your switch????
mac address-table notification change interval 0
I think tha may be due the this issue......4500E may not be releasing the mac so.........
If helps u plz...dont forget rating....
Thank You
Milan
Thanks Milan, I believe the command you mention is for SNMP traps?
