Switch Port LED not Blinking
nguessankmatt
Hello team,
We face a problem. We have a Cisco 9000 series switch, specifically a 9200.
It is used as an access switch. He is in production and works perfectly. however, the LEDs of the different ports do not blink.
After restarting, the LEDs work for a moment and go out afterwards.
Can you give me a solution in order to solve this problem?
Thanks for help.
9 Replies 9
balaji.bandi
So the Activity of the LED Stops, and how about Data ? is the connectivity ok?
BB
Hi.
Data and connectivity are good.
Thanks.
what is the version of OS running? and as suggested can you check and post the logs to see any abnormal detected?
BB
marce1000
 - After restart also check the logs (show logging) ; watch out for peculiar and or error messages, if any.
   M.
Leo Laohoo
What is the exact firmware version you're running?
JonMoss92624
I have the same issue, it affects port 24 - it's a C9200L-24T-4X Fuji 16.9.3
Nothing in the logs, probably a design flaw
Yes your right, thank you it's a known bug https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvp90710
I will update the switches with the issue to the fixed release
i have observed moved to 16.12.x has some fix.
BB
