10-02-2024 09:45 PM
I want to know the temperature for the switch for the model - CBS350-8P-2G 8-Port Gigabit PoE Managed Switch.
I have tried the command
sh env all
Internal power supply Active.
Fans status is N/A
TEMPERATURE is OK
Why fan is showing here N/A here? How to know the know exact current temperature for this model switch?
10-03-2024 12:15 AM
Look at the datasheet and table which can provide which one have FAN or FAN Less:
Power Efficiency
The Cisco Business 350 Series Switches integrate a variety of power-saving features across all models, providing the industry’s most extensive energy-efficient switching portfolio. These switches are designed to conserve energy by optimizing power use, which helps protects the environment and reduce your energy costs. They provide an eco-friendly network solution without compromising performance. Cisco Business 350 Series Switches feature:
● Support for the Energy Efficient Ethernet (IEEE 802.3az) standard, which reduces energy consumption by monitoring the amount of traffic on an active link and putting the link into a sleep state during quiet periods
● Automatic power shutoff on ports when a link is down
● Embedded intelligence to adjust signal strength based on the length of the connecting cable
● Fanless design in most models, which reduces power consumption, increases reliability, and provides quieter operation
10-03-2024 08:49 PM
How to know the exact temperature of this model switch.
10-04-2024 10:43 AM - edited 10-04-2024 10:44 AM
The datasheet provided the temparature that condition that switch condition works. this switch is SMB swsitch not enterprise grade switch.
I have seen that option when i was using those models - (i may be wrong)
if i were you i get small environment device IOT for server room, many available in the market.
