Switch to terminate 100Gig point to point L2 link from SP
raghav.rai
Can you please suggest me a switch to terminate 100gig link to terminate a L2  point to point link from service provider. Switch should support Q in Q and Link Loss Forwarding ( Interface of the switch should go down if L2 link from provider fails).
Tks,
Raghavendra
Thank you but Cisco feature navigatore does not show 9200/9300 supports Q in Q feature. Also Link Loss forwarding is not supported on these switches. I am looking for something like Metro Ethernet Swicthes that Cisco had couple of years back. Do we have Metro Ethernet equivallent swicthes now?
OP question you  looking 100GB connection and QinQ support- we suggested Cat 9300 or Cat 9500 For Ethernet connection.
If you looking carrier grade - suggest to contact Local partner with you requirement, they have sales tool and give you exact model for your use case.
Other models you can look :
https://www.cisco.com/c/en/us/products/collateral/routers/network-convergence-system-5000-series/datasheet-c78-736153.html
New Platform Cat 8K -  (please check the product guide and your features can support)  - not sure or come across has 100GB support ?
https://www.cisco.com/c/en/us/products/routers/cloud-edge/index-b.html#/
BB
9K is new series of cisco SW.
connect Cisco for more support for platform select.
