switch
muraripadhan
Level 3
Level 3
Dears
Please tell me how i will upgrade firmware,ios and how i will get patch file
InayathUlla Sharieff
Hi Murari,
Please login to the Cisco software download page and select the product and firmware you would like to upgrade to and then download the same from the site. Once you are download upload it to the Switch/router via tftp or usb.
then change the boot varaiable to the new one and reload the switch.
hope this help.
Inayath
Additional, below you will find the process to follow for some switches, basically it is the same for the most of the devices, but you could verify the process for you specific switch model:
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/20685-129.html
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-3850-series-switches/117552-technote-cat3850-00.html
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
