Switching
muraripadhan
Dears,
I have 100 switches in my network
In every switch i have Admin username and password.
My username is "Admin"
       Password is "@dmin@d205"
       Enable password "@dmin@502
But my requirement
My manager said that for another user who can only view permission he can not modify any switch.
So how can  i configure another username and password with different "enable password' for that user, that user can only see permission.
I have to configure in every switch.
Please suggest me.
thanks and regards
Murari Mohan Padhan
james.buchanan1
First, don't post usernames and passwords on public forums.
Second, I believe you can create a username and password with privilege 7 that will give only read-only rights. Something like:
username <username> privilege 7 password 0 <password>
James
As it was mentioned previously you could configure a username with privilege 7 and provide just the needed commands using privilege command line:
conf t
privilege exec level 7 <the allowed commands>
example
privilege exec level 7 show run  <-- the user will have access to see the show running config only.
This link could be useful
http://www.ciscozine.com/multiple-privilege-levels/
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Sir this is not my actual user name and password.
I know that how to create username and privilege 7 password but
Sir
When i create another name and password and i login from that username and password at that time its asking for enable password and after giving the the enable password.That user can  modify that switch.
Due to how i will protect my switch from that specific user?
Can i create different enable password for that user?
