Switchport Amber and Green Blinking
Hello All,
Please find the attached video in which port number 1 & 2 continuously getting green and Amber. Is it a L2 Cabling issue or any other reason???
balaji.bandi
what is the model of the switch and what logs you see on the console ?
in general :
STAT
(port status)
Off
No link, or port was administratively shut down.
Green
Link present.
Blinking green
Activity. Port is sending or receiving data.
Alternating green-amber
Link fault. Error frames can affect connectivity, and errors such as excessive collisions, cyclic redundancy check (CRC) errors, and alignment and jabber errors are monitored for a link-fault indication.
Amber
Port is blocked by Spanning Tree Protocol (STP) and is not forwarding data.
Note After a port is reconfigured, the port LED can remain amber for up to 30 seconds as STP checks the network topology for possible loops.
Blinking amber
Port is blocked by STP and is not sending or receiving packets.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/hardware/installation/guide/3750hig/HIGOVERV.html#wp1136573
BB
balaji.bandi
in general :
STAT
(port status)
Off
Green
Link present.
Blinking green
Amber
Blinking amber
BB
It is Cisco 2960-24-TCL, not having access to console or SSH/Telnet so unable to check logs .
So by looking your post Switchport is having issue with Point No. 4,  "Link fault. Error frames can affect connectivity, and errors such as excessive collisions, cyclic redundancy check (CRC) errors, and alignment and jabber errors are monitored for a link-fault indication."
