Switchport Latency
NRHelpdesk_2
Is it possible to configure/specify a latency value for a specific switcport on a 3750?
Thank you
5 Replies 5
vmiller
Level 7
Level 7
No. Just curious, what are you attempting to accomplish with this ?
Thank you for the response. Basically I am trying to mimic a 2MB "slow" connection between 2 locations.  I've limited the bandwidth on the port and that's working properly. I didn't think this was possible and thank you for confirming.
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind.  Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Don't know a way to do that on the switch.  However, there are line impairment devices that will allow you to emulate latencies and/or lost packets.  Believe you can create such a device using a PC with two NICs and (free) software.
Antonio Knox
Level 7
Level 7
No, but you can give certain traffic priority with QoS, which can help improve latency issues with important traffic.
I am actually looking for this config, can you pls post a config example to give certain traffic priority over other, by differentiaing traffic by port, ip address, vlan or traffic type.
