System returned to ROM by RPR Switchover
a.kumaresan
I have a catalyst 4500 switch. I have a problem.
------------------ show version ------------------
IOS (tm) Catalyst 4000 L3 Switch Software (cat4000-I9K91S-M), Version 12.2(20)EW, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Wed 02-Jun-04 18:32 by hqluong
Image text-base: 0x00000000, data-base: 0x012B38D0
ROM: 12.1(12r)EW
Dagobah Revision 93, Swamp Revision 24
Switch-2 uptime is 15 weeks, 4 days, 11 hours, 58 minutes
System image file is "bootflash:cat4000-i9k91s-mz.122-20.EW.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C4507R (MPC8245) processor (revision 5) with 524288K bytes of memory.
Processor board ID FOX06381M87
MPC8245 CPU at 333Mhz, Supervisor IV
Last reset from Reload
7 Virtual Ethernet/IEEE 802.3 interface(s)
144 FastEthernet/IEEE 802.3 interface(s)
58 Gigabit Ethernet/IEEE 802.3 interface(s)
403K bytes of non-volatile configuration memory.
Can somebody tell me is it a hardware issue or software issue. I couldnt find any bug related to 4500 platform . But I found a similiar bug in C10720: Invalid RPR switchover description. On a single RP router reload reason is being shown as "RPR
switchover"
Note: This can affect multiple platforms, not just c10720. This includes
7200, 12000, 7500..
The bug id is CSCdx57239
smothuku
Level 7
Level 7
Hi ,
Can you paste show-tech of the switch.
satish
