Ipconflict with NAT
mathiasivn
Design
Pc1vlan1-->
SW ----> Ruter --->> ruter
Pc1vlan2-->
pc1vlan1 ip 10.102.79.5/20 GW 10.102.79.254
pc1vlan2 ip 10.152.79.4/20 GW 10.102.79.254
with the below mentioned configuration, vlan1 workstation and router keep on poping up ip conflict error message. there is only single workstation in each vlan
the configuration of the as follow
interface FastEthernet0/0
ip address 10.248.1.1 255.255.255.252
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/0.1
interface FastEthernet0/1
no ip address
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1.1
encapsulation dot1Q 1 native
ip address 10.102.79.254 255.255.240.0 secondary
ip address 172.18.1.254 255.255.255.0
no snmp trap link-status
interface FastEthernet0/1.2
encapsulation dot1Q 2
ip address 10.152.79.254 255.255.240.0 secondary
ip address 172.20.1.254 255.255.255.0
interface Content-Engine1/0
no ip address
shutdown
router ospf 1
log-adjacency-changes
network 10.248.1.1 0.0.0.0 area 0
network 172.18.1.254 0.0.0.0 area 0
network 172.20.1.254 0.0.0.0 area 0
ip classless
no ip http server
no ip http secure-server
ip nat inside source static network 10.102.79.0 172.18.1.0 /24
ip nat inside source static network 10.152.79.0 172.20.1.0 /24
I want achieve the two subnets/vlan 10.102.79.0/20 and 10.152.79.0/20 has to be nated with 172.18.1.0/24 and 172.20.1.0/24 address.. Please guide me where I am missing...
lgijssel
Level 9
Level 9
You should not use the secondary adresses. This problem can be solved using nat pools and route maps. Please consult the link below for more info on NAT:
http://www.cisco.com/en/US/tech/tk648/tk361/tk438/tsd_technology_support_sub-protocol_home.html
Leo
