t1 multilink ppp routing
networksavvy
I have an adtran 4205 and a cisco 1800 at two offices. I have 2 t1's at each site installed for load balancing, etc dedicated to network traffic only. I used multilink ppp and have the ppp1 interface on each router up, and both t1's on each router showing up. all is fine. for the ppp 1 interfaces on each router, I used 192.168.1 255.255.255.252 and 192.168.1.2 255.255.255.252 respectively. All seems fine there. I can ping and telnet back and forth using those addresses. For the main office router, the important lan range is 10.1.3.x and 10.1.5.x 255.255.0.0 and at the remote site 10.2.4.1 255.255.255.0 Both sides have a seperate firewall which holds the routes for internet traffic on a seperate connection. The main router has 0.0.0.0 0.0.0.0 10.1.3.20 (firwall at main site) and the remove site has 0.0.0.0 0.0.0.0 10.2.4.10 (firewall for remote site)
From REMOTE Test Router: (10.2.4.1 255.255.255.0, 192.168.1.2 255.255.255.252)
ping 10.1.3.5 source 10.2.4.1 request timed out
ping 10.1.3.5 source 192.168.1.2 success!
ping 192.168.1.1 source 10.2.4.1 request timed out
From MAIN Test Router (10.1.3.5 255.255.0.0, 192.168.1.1 255.255.255.252)
ping 10.2.4.1 source 10.1.3.5 expired TTL in transit
ping 10.2.4.1 source 192.168.1.1 request timed out
ping 192.168.1.2 source 10.1.3.5 success!
Is this a static route issue? I even tried configuring the 0.0.0.0 routes as the 192.168.1.x addresses of the other routers, or even 0.0.0.0 0.0.0.0 ppp1 and still cant talk accross to the other LAN. Any suggestions?
no problem... you can use it... i think both the way your work will be done...
rate the post if it helps
regards
Devang
23 Replies 23
Richard Burts
Spencer
We probably could tell more exactly what the problem is if you would post the output of show ip route from both routers. But it sounds fairly simple from your description. My guess is that the MAIN router does not have a route to 10.2.4.0. Try putting this on the MAIN router:
ip route 10.2.4.0 255.255.255.0 192.168.1.2
Give it a try and let us know if it solves it. If it does not, then please post the output of show ip route.
Rick
Rick
devang_etcom
Level 7
Level 7
is it possible to post the show run output of both the side... and i want to know about the routing enabled in your network including static and default router configuartion...
regards
Devang
Ok, make sure to ignore the HDLC interfaces on the main router. That is the current setup on a swapped out router to keep the remote office up. I have the router in question brought into this office plugged directly into the main router via t1 crossover cables.
Also, I currently dont have anything plugged into the eth port of the remote router - which is why there may not be anything for the 10.2.4 range in its own routing tables. This should not deter my tests trying to ping by IP address of 10.1.4.1 from MAIN to REMOTE, should it?
I also tried adding that static route to the PPP address of the other router. Pinging 10.2.4.1 from 10.1.3.5 still doesn't work.
Thanks again all.
CONT...
CONT.
MAIN
ip subnet-zero
ip classless
ip name-server 10.1.3.104
ip routing
ip multicast-routing
ip mcast-stub helper-address 10.1.190.190
no ip firewall alg h323
no ip firewall alg sip
qos map NBX 10
match dscp 46
priority 512
interface eth 0/1
description BR Network
ip address 10.1.3.5 255.255.0.0
no ip proxy-arp
ip mcast-stub upstream
no shutdown
interface eth 0/2
description NBX Phone Network
ip address 10.2.5.1 255.255.255.0
no ip proxy-arp
no shutdown
interface t1 3/1
description NO T1 1
tdm-group 1 timeslots 1-24 speed 64
no shutdown
interface t1 3/2
description LC T1 1
no shutdown
interface t1 3/3
description BB T1 1
no shutdown
interface t1 3/4
description NO T1 2
no shutdown
interface t1 3/5
description NEW ORLEANS T1 1 TEST
clock source internal
tdm-group 5 timeslots 1-24 speed 64
no shutdown
interface t1 3/6
description NEW ORLEANS T1 2 TEST
tdm-group 6 timeslots 1-24 speed 64
no shutdown
interface t1 3/7
shutdown
interface t1 3/8
shutdown
interface ppp 1
ip address 192.168.1.1 255.255.255.252
ip mcast-stub downstream
ip mcast-stub helper-enable
ppp multilink
qos-policy out NBX
no shutdown
cross-connect 5 t1 3/5 5 ppp 1
cross-connect 6 t1 3/6 6 ppp 1
interface hdlc 1
description NO T-1 CenturyTel
ip unnumbered eth 0/1
qos-policy out NBX
no shutdown
cross-connect 1 t1 3/1 1 hdlc 1
interface hdlc 2
description LC T-1 CenturyTel
qos-policy out NBX
no shutdown
cross-connect 2 t1 3/2 1 hdlc 2
interface hdlc 3
description BB T-1 CenturyTel
qos-policy out NBX
no shutdown
cross-connect 3 t1 3/3 1 hdlc 3
interface hdlc 4
description NO T-1 Nuvox
qos-policy out NBX
no shutdown
cross-connect 4 t1 3/4 1 hdlc 4
interface hdlc 5
no ip address
shutdown
interface hdlc 6
no ip address
no shutdown
router rip
version 2
redistribute static
redistribute connected
network 10.2.0.0 255.255.0.0
network 10.1.0.0 255.255.0.0
network 192.168.1.0 0.0.0.3
ip access-list extended UDP-FORWARD
permit udp any eq netbios-ns any
permit udp any eq netbios-ss any
permit udp any eq netbios-dgm any
ip route 0.0.0.0 0.0.0.0 10.1.3.20
no ip tftp server
ip http server
ip http secure-server
no ip snmp agent
no ip ftp agent
REMOTE
ip classless
ip routing
ip load-sharing per-packet
qos map NBX 10
match dscp 46
priority 512
interface eth 0/1
description NO LAN
ip address 10.2.4.1 255.255.255.0
ip igmp immediate-leave
no shutdown
interface eth 0/2
no ip address
shutdown
interface t1 1/1
description NO T-1
no shutdown
interface t1 2/1
tdm-group 2 timeslots 1-24 speed 64
no shutdown
interface ppp 1
ip address 192.168.1.2 255.255.255.252
ppp multilink
qos-policy out NBX
no shutdown
cross-connect 1 t1 1/1 1 ppp 1
cross-connect 2 t1 2/1 2 ppp 1
router rip
version 2
network 10.2.2.0 0.0.0.255
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip route 10.1.0.0 255.255.0.0 192.168.1.1
SHOW IP ROUTES
MAIN
Codes: C - connected, S - static, R - RIP, O - OSPF, B - BGP
IA - OSPF inter area, N1 - OSPF NSSA external type 1
N2 - OSPF NSSA external type 2, E1 - OSPF external type 1
E2 - OSPF external type 2
Gateway of last resort is 10.1.3.20 to network 0.0.0.0
S 0.0.0.0/0 [1/0] via 10.1.3.20, eth 0/1
C 10.1.0.0/16 is directly connected, eth 0/1
R 10.2.1.0/24 [120/1] via 10.2.1.1, hdlc 2
R 10.2.2.0/24 [120/1] via 10.2.2.1, hdlc 4
R 10.2.3.0/24 [120/1] via 10.2.3.1, hdlc 3
S 10.2.4.0/24 [1/0] via 192.168.1.2, ppp 1
C 10.2.5.0/24 is directly connected, eth 0/2
C 192.168.1.0/30 is directly connected, ppp 1
C 192.168.1.2/32 is directly connected, ppp 1
REMOTE
Gateway of last resort is 192.168.1.1 to network 0.0.0.0
S 0.0.0.0/0 [1/0] via 192.168.1.1, ppp 1
S 10.1.0.0/16 [1/0] via 192.168.1.1, ppp 1
C 192.168.1.1/32 is directly connected, ppp 1
Spencer
Before I even start to look at the configuration material that you posted, I think we need to clarify your comment about the Ethernet of the remote router. Did I understand correctly that there is nothing plugged into it? If there is nothing plugged into it, then the interface is most likely in the line is up, line protocol is down state. And if the line protocol is down then this does in fact explain your issue. If the interface for 10.2.4.1 is line protocol down then attempts to ping to it or attempts to ping from it will fail.
Before we go further with this you need to get something in to it so that it is protocol up.
[edit: I just saw the message that you posted which includes the show ip route from both routers. This confirms what I have said. There is no route for 10.2.4.0 as a connected interface. This indicates that the interface is almost surely in the protocol down state. And this IS the problem. Get the interface up and up before we try to do anything else. Devang's suggestion of creating a loopback on the remote router and assigning 10.2.4.1/24 to the loopback would be a quick way to test - you probably need to remove the address from the Ethernet before you try to put it on the loopback.]
Rick
Rick
yes do one thing configure the loopbakc address with the one of the ip address from 10.2.4.x for testing purpose... and then try to ping...
it means create loopback interface and then assign ip address of 10.2.4.x series...
# interface loopback n
# ip address 10.2.4.x subnetmask
regards
Devang
It's working!! You guys were right, nothing plugged in - no responses. Thanks a ton. I could have swore that I had configured eth int on routers before with just an ip and was able to ping from the neighboring router. Must have been a brain fart!
One question. Are there any dis/advantages to using ppp1 in the route instead of the actual opposite interface?
Thanks again guys, much appreciated.
regards
Devang
One other thing now. I cannot ping from one branch LAN to another branch LAN through MAIN. RIP is properly distributing. But, I'm now trying to ping over the ppp1 to hdlc interfaces. IE: From the new 10.2.4.x network pinging to LC at 10.2.1.1 - I get response. But, if I ping a known host - I dont. From the LC router, I cannot ping 10.2.4.1 or anything else on the .4 network. What kind of static route will I have to add to LC router to let it know that 10.2.4.x is 2 hops away through main? Note: All across-office pinging works now on the production single t1 setup using 100% hdlc. It's not working right now with the mppp example from above.
Thanks!
i am not clear with your explanation will you please explain it in more details or with some diagaram so i can help you out...
regards
Devang
Sorry - let me clarify. Will I have to add static routes to any of the routers for the 10.2.4.1 router to be able to communicate with the routers that are connected to the 10.1.3.5 over the HDLC links?
All of the other sites connect to the MAIN BR router in a hub and spoke... I am just wondering if the configuration that I got working in the office will share RIP information over the PPP link about the sites that the 10.2.4.1 router doesn't know about, but that the 10.1.3.5 does?
I can't test that as I am in the main office, and will be driving out to switch the router with the tested one at the remote office in the morning.
Spencer
With most dynamic routing protocols you should not need to configure any static routes. Assuming that you have network statements in the routing protocol for the PPP link and for the LAN/loopback interfaces then the protocol should advertise all the subnets to all the routers and everything should be reachable.
There is an issue when the protocol is RIP version 1. RIP is a classful routing protocol and one important thing that means is that RIP will summarize over network boundaries. What that means in practical terms is that if 10.2.4.0 is the LAN and 192.168.1.0 is the PPP, then RIP will only advertise a summary route for 10.0.0.0 over the PPP. And this means that the MAIN will not see a route to 10.2.4.0. With RIP version 2 you have an option to configure no summarization which would resolve the issue. So if you add the command under router rip to turn off automatic summarization you should be ok.
I did notice in the config that you posted for remote this:
router rip
version 2
I assume that it is a typo mistake that the network statement should be for 10.2.4.0 rather than 10.2.2.0.
Rick
Rick
