Tagged vlan on Catalyst 3750
pradeep.kudlur
Could someone please tell me how to tag a physical port to multiple vlans on Cisco switch.
Eg :
There are 5 vlans with id 10,20,30,40,50 I need to tag port 1 to above listed valns. What are the set of commands do I need to execute. Thanx in advance !!
amit-singh
Level 8
Level 8
Hi Pradeep,
On port 1 do like
conf t
interface fa 0/1
switchport mode trunk
no shut
By default on Cisco switches vlan1 is native vlan and the Vlan 1 traffic is not tagged. If you want to tag the Vlan 1 traffic also then you have to use a global config command " vlan dot1q tag all".
HTH, Please rate if it does.
-amit singh
Hi Amit,
Thax for the reply. What am trying to do in not just create a tagged port. I want to pag a physical port to multiple vlans. What I mean, would like port 1 to be member of vlan10, vlan20,vlan30 ...
I tried the following thing :
config t
interface gig0/1
switchport access vlan 10
switchport access vlan 20
switchport access vlan 50
end
But when I do show vlan I could see port 1 is only member of last vlan in the sequence i.e vlan50.
-pradeep
Hi Pradeep ,
configure the gig0/1 like this.
int g0/1
switchport nonegotiate
switchport trunk native vlan 1
switchport trunk allowed vlan add 10,20,30,40,50.
Check the show vlan output.
Hope it helps you.
satish
you cannot make a "access port" in multiple vlans . You can make the port a trunk to carry multiple vlans . The only way i could think of doing this would be create a layer 3 SVI with multiple secondary addresses and assign that port into the vlan . If the device on the port needs to be in multiple vlans it would have to be able to trunk .
