Telnet issue to cisco 2960 switch
gamage123
I have a cisco 2960 switch.
I can ping this switch without any loss.
No issue in connectivity. when the telnet command is issued it telnets the switch and ask the telnet password. But when I am typing the password i get disconnected automatically.
Please help to solve this.
Do you have the basic telnet config
2960#config t
2960(config)#line vty 0 4
2960(config-line)#password xxxxx
2960(config-line)#login
If its there make sure that there isnt any device using the same ip as switch
Syed
glen.grant
While you are at it set your enable secret password also .
I think it's problem related to ip conflict
Please check the change the switch ip and check again
